Going to my first autox this sunday!!
Originally Posted by CivicSiRacer
Actually when you hear the tires screeching you've already pushed past the limits of your tires. Most novice drivers usually drive 12/10ths instead 9/10ths or 10/10ths.
My recommendation for novices is to turn on your A/C cause it will limit your car to 9/10ths, and the most you can drive your car is 9/10ths.
This is the point at which the contact patch is just barely sliding a little. It's not sliding much, so you still have control. This represents maximum traction for most tires and is the reason Bob Bondurant says "a squealing tire is a happy tire."
And many cars drop the AC clutch solenoid at WOT (so it won't really do anything when you want to go fast). And even if the car doesn't, you wont lose 10% of your power, and peak power doesn't matter in a real curve anyway.
Originally Posted by Nathan1234
Wrong and wrong.
Wrong and wrong.
i'm sure bob wasn't referring to street tires or even r compounds. race slicks are different.
also if your tires are sliding then you have less control. the advice however probably holds true for seasoned autoxers. however, we are talking about a beginner where squeeling tires = wayyy over driving the car which results in very slow times.
also the AC advice still stands. why? because in an autox rarely are you at full throttle for more than a second or two. Even in a relatively long course you wont be full throttle for more than say 3-4 seconds and that would be a very long straight.
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally Posted by WiLL
Originally Posted by g10 526
one of my friends is an instructor for nasa so hes the one whos pushing me to do this, im just afraid of sliding out and knocking over all the cones, i guess its nothing but a dent in my ego but i dont know, im going in with the mentality that i suck and just want to learn, thanks for the tips guys, ive taken some turns with dsc on and it just cuts off my power and liek forces me to go straight or something, the feeling really isnt pleasant but ill take your advice and leave it on for my first runs, thanks again guys
And as for the screeching tires... I dunno about you guys, but every driver I've ever seen abusing his tires (making a lot of noise) has gotten chit times. I dunno what kind of tires are *supposed* to be squealing, but in my experience, a screeching tire is a sliding tire.
A screeching tire is a sliding tire. Load any tire in a turn and it'll be a sliding one. Tire slide and tire deformation result in slip angle, so any tire with a slip angle has some degree of slide. What's important though is not to think of tire noise as an indicator of the limit of adhesion.
My tires make plenty of noise before before losing traction, and most others that I've owned do the same. The Firehawk SZ50/EP's I had were the exception, though. They would barely make noise no matter what I did (even if I went WAY over the limit), but I could feel when I was actually approaching the limit so it didn't matter.
Maybe I just don't understand what you are saying.... if you aren't using full throttle (and are therefore making some amount of power substantially below full engine output), why would it matter if you have accessories running or not, considering you could just push the gas a little more and get the same part-throttle engine output as you could without AC running?
the whole point of the A/C thing is just to make you forget about the gas and focus more on your line. It has less to do with power output (obviously, more power is better, all other factors being equal) and more to do with the psychological affects of driving a pokey car.
Regardless of the reasoning, its proven to work on nooby racers and more experienced guys trying to get a little better. I think rick is commenting on the relative scarcity of WOT opportunities just to demonstrate the importance of precise driving... just to show that power really isn't important.
keys to a good time (in order of importance):
1. driver
2. tires
3. driver
4. suspension/allignment
5. driver
6. power
1. driver
2. tires
3. driver
5. driver
6. power
1. driver
2. tires
3. driver
5. driver
6. power
1. driver
2. tires
3. driver
5. driver
6. power
My laundry list of first-time autocrosser advice is here -
http://accordinglydone.com/forum/sho...&threadid=4170
- it's the 6th reply on the 1st page.
Originally Posted by SpecialED
I've never tried the A/C thing myself or recommended it, but I have told a few novice drivers after riding with them - "you know, if you don't try so hard to go fast, you will go faster."
