Solid racing control arm bushings for EF (crx and civic)
Old 07-06-2003, 07:43 AM
BTLFED
I eat paint chips.
BTLFED's Avatar
Originally posted by JinMTVT
have you guys actually VISIT my website?
ahahahaha
I did, that is what prompted the other questions.
BTLFED is offline
Old 07-06-2003, 09:30 AM
JinMTVT
JinMTVT's Avatar
what do you guys think of the color of our kit ?
hahahaah
to me it was 0 important..but newya we didn't have the choice..
material limited
i woudl've preferred dark grey though..
JinMTVT is offline
Old 07-06-2003, 09:53 AM
BTLFED
I eat paint chips.
BTLFED's Avatar
I would have preferred red to match my prothane bushings in the rest of the car.
BTLFED is offline
Old 07-06-2003, 12:03 PM
JinMTVT
JinMTVT's Avatar
BTLFED: ahhaah nice one
soon u will have other colors because you will be beeing our full spherical bearing conversion kit!
you know why u will be buying it ???
eheh
simple..because there won't by anything like it perofrmance and cost wise!
JinMTVT is offline
Old 07-06-2003, 03:32 PM
BTLFED
I eat paint chips.
BTLFED's Avatar
Oh really? We will see. Actually you are right, I prefer function over form.
BTLFED is offline
Old 07-06-2003, 05:30 PM
jaje
HC Racer H5
jaje's Avatar
what is used to lubricate the bushings?...graphite?
jaje is offline
Old 07-06-2003, 07:11 PM
JinMTVT
JinMTVT's Avatar
IF you mean what we recommend to use,
any automotive grease will do the trick since our bushings are already auto lubricated.
As explained on the website, the material contains mini pockets of oil and teflon based lubricants.Each times a micron of the surface use down, some lubricant is released.
Here is a magnification of the surface of the material:
you can run the bushings without any lubrication, but it is always better to put some grease to protect the bushings from salt,dirt and chemicals...
It also helps keeping the dirt away thus giving it longer lifetime ..
JinMTVT is offline
Old 07-06-2003, 08:49 PM
jung4g
Asianalize your car
jung4g's Avatar
seems damn expensive... for 4 bushings!! I'll just deal with the poly complete kit for not much more...
Jung
jung4g is offline
Old 07-07-2003, 04:59 PM
JinMTVT
JinMTVT's Avatar
no problem Jung..
but just go check out the price at wich other companies are selling solid control arm bushings ...
then polys are a really good replacement fro worn out factory bushings.. but i guess except for the squeaks on a brand new car you can replace the upper control amr bushings with poly ones and you wouldn't be able to tell the difference..
you know why ? because there is no or almost no gain in performance because they are still " compliants" ..
but neway poly bushings are good cheap alternative for replacing worn out bushings in most LCA parts..
( though unfortuantly they start wearing out extremely quick and they start from hard to soft in just about 1-2 years when driven hard )
JinMTVT is offline
