Aem Ems
HAN Approved Vendor
Aem Ems
AEM’s Plug & Play Engine Management System (EMS) will forever change the way you look at and perform fuel injection tuning! This user-programmable system plugs directly into a vehicleÂ’s factory ECU harness and requires no additional wiring or hardware. Windows-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish ''quick keys'' to any pertinent information during the tuning process.The AEM EMS’s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
Features :
Plug and Play Technology! No Wiring Necessary
Uses all the Factory sensors
Fuel Table Automapping
Base Maps Included
Programmable Traction Control
Onboard 512kb Datalogger
10cyl sequential fuel injection capability
Much Much more!
Select your application from the list below:
Acura Programmable EMS
Dodge Programmable EMS
Ford Programmable EMS
Honda Programmable EMS
Mazda Programmable EMS
Mitsubishi Programmable EMS
Nissan Programmable EMS
Subaru Programmable EMS
Toyota Programmable EMS
free shipping
http://www.prostreetonline.com...M+EMS
AEMÂ’s Plug & Play Engine Management System (EMS) will forever change the way you look at and perform fuel injection tuning! This user-programmable system plugs directly into a vehicle’s factory ECU harness and requires no additional wiring or hardware.* Windows™-based software (2000, NT, 98, 95, ME) makes the task of copying, viewing and manipulating data as simple as a click of the mouse. User-defined templates are easily configurable and enable tuners to establish “quick keys” to any pertinent information during the tuning process.The AEM EMS’s infinitely adjustable software allows tuners to program virtually any combination of engine control, power adders and auxiliary devices, and accurately deliver proper amounts of fuel and correct ignition timing for ANY boost level or operating condition.
Installs in Minutes
Plug & Play Technology - No Wiring Necessary
Uses all the Factory Sensors
Base Maps Included
10 Cyl Sequential Fuel Injection
16 General Purpose Outputs
7 Definable Switch Inputs
Electronic Boost Control
Soft Cut Rev Limiters
2 Step Launch Control
Wet or Dry Nitrous Control
Definable Knock Control
Full Idle Control
4 EGT Inputs w/Fuel Control
16/32 Hybrid High-Speed Processor
AEM EMS Sensor Kits
AEM offers several sensor kits for vehicles that require additional outputs and/or upgraded hardware over existing sensors. All sensors come with a three-wire mating connector with 12'' leads for ease of installation
AEM UEGO Controller
AEM’s Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit!
AEMs Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED ''needle'' that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16'') gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Features :
Base Maps Included
Much Much more!
free shipping
Installs in Minutes
Base Maps Included
Full Idle Control
AEM EMS Sensor Kits
AEM UEGO Controller
Boosted R 25
Engine Swaps, Tech & Tuning
19
04-18-2004 12:19 PM
DamonBoost
09-02-2002 10:17 AM
