AEM Big Rotor Brake Upgrade
HAN Approved Vendor
O.E. Caliper Big Rotor Brake kit - allows for use of O.E. brake caliper, making it the most affordable big rotor system on the market. AEM's rotors have an average 20% larger surface area and can reduce a vehicle's stopping distance by up to 33%. These oversized rotors also increase brake torque for reduced pedal effort and have a greater thermal capacity that extends performance during continuous hard braking. Venting and drilling was a key consideration in the engineering process of the rotors and ensures maximum heat dissipation for reliable, consistent braking. The utilization of CNC-machined 6061-T6 billet aluminum rotor hats dimininshes the rotor's tendency to cup under extreme prolonged use and reduces the overall weight of the rotor when compared to cast versions. The AEM Big Rotor Brake Kit includes caliper repositioning brackets, complete Premium Grade and aircraft-quality hardware, comprehensive instructions and AEM decals. Key features include:100 percent bolt on kit (no cutting or drilling), All big rotors systems are ABS compatible, Rotors are Gold Zinc plated to prevent rust, Utilizes stock pads or can upgrade to AEM brake pads, Lightweight rotor hats are laser etched and available in blue, red, and silver for show quality dress up looks, Manufactured and assembled in the USA. All kits require at least 16 in. wheels for caliper clearance. Some kits require 17 in. or larger wheels for caliper clearance (subject to wheel back-spacing) - please contact us upon ordering. Rotors available in BLUE, RED, or Clear colors. When ordering desired color insert -B- for blue, -R- for red, or -C- for clear after the part number to indicate desired color. All part numbers listed below will have -C- for clear after the part number. There is no change in pricing for AEM Rotor optional colors.
Acura CL 2.3L 4cyl. 1998-1999 1998 - 1999 Acura CL 2.3L 4cyl. O.E. Cal. Front Brake kit 29-512C $469.00
Acura CL 2.2L 1997-1997 1997 Acura CL 2.2L O.E. Cal. Front Brake kit 29-511C $435.00
Acura Integra Type-R 1997-2001 1997 - 2001 Acura Integra Type R O.E. Cal. Front Brake kit 29-519C $469.00
Acura Integra exc. Type-R 1990-2000 1990 - 2000 Acura Integra exc. Type R O.E. Cal. Front Brake kit 29-900BL $409.00
Acura Integra incl Type-S 1998-2001 1998 - 2001 Acura Integra Type-R O.E. Cal. Rear Brake kit 29-618C $474.00
Acura Integra exc. Type-R 1990-2001 1990 - 2001 Acura Integra all exc. type-r O.E. Cal. Front Brake kit 29-700BL $409.00
Acura RSX base 2002-2003 2002 - 2003 Acura RSX O.E. Cal. Front Brake kit 29-703BL $429.00
Acura RSX type-s 2002-2003 2002 - 2003 Acura RSX type-s O.E. Cal. Front Brake kit 29-704BL $429.00
Acura RSX incl Type-S 2002-2003 2002 - 2003 Acura RSX incl. Type-S O.E. Cal. Rear Brake kit 29-904BL $443.00
Dodge Stratus V6 2001-2003 2001 - 2003 Dodge Stratus V6 O.E. Cal. Front Brake kit 29-563C $439.00
Honda Accord all 1990-1997 1990 - 1997 Honda Accord O.E. Cal. Front Brake kit 29-511C $435.00
Honda Accord V6 Coupe 1998-2002 1998 - 2002 Honda Accord V6 Coupe O.E. Cal. Rear Brake kit 29-623C $493.00
Honda Accord 4cyl. 1998-2002 1998 - 2002 Honda Accord 4cyl. O.E. Cal. Front Brake kit 29-512C $469.00
Honda Accord V6 1998-2002 1998 - 2002 Honda Accord V6 O.E. Cal. Front Brake kit 29-514C $464.00
Honda Civic Si w/ ABS 1992-1995 1992 - 1995 Honda Civic Si w/ ABS O.E. Cal. Front Brake kit 29-900BL $409.00
Honda Civic Si 1999-2000 1999 - 2000 Honda Civic Si O.E. Cal. Front Brake kit 29-900BL $409.00
Honda Civic EX 1996-2000 1996 - 2000 Honda Civic EX Rear Drum to Disc Conv. kit 29-601BL $795.00
Honda Civic EX 1992-1995 1992 - 1995 Honda Civic EX Rear Drum to Disc Conv. kit 29-602BL $795.00
Honda Civic Si 2002-2002 2002 Honda Civic Si (2pc. Rotor) O.E. Cal. Rear Brake kit 29-603BL $449.00
Honda Civic EX 1992-2003 1992 - 2003 Honda Civic EX O.E. Cal. Front Brake kit 29-700BL $409.00
Honda Civic Si w/ ABS 1992-1995 1992 - 1995 Honda Civic Si w/ ABS O.E. Cal. Front Brake kit 29-700BL $409.00
Honda Civic Si 1999-2000 1999 - 2000 Honda Civic Si O.E. Cal. Front Brake kit 29-700BL $409.00
Honda Civic LX 2001-2002 2001 - 2002 Honda Civic LX O.E. Cal. Front Brake kit 29-700BL $409.00
Honda Civic Si HB 2002-2003 2002 - 2003 Honda Civic Si HB O.E. Cal. Front Brake kit 29-700BL $409.00
Honda CRV all 1997-2001 1997 - 2001 Honda CRV O.E. Cal. Front Brake kit 29-519C $469.00
Honda Prelude non vtec 1992-1996 1992 - 1996 Honda Prelude non vtec O.E. Cal. Front Brake kit 29-512C $469.00
Honda Prelude Si vtec 1992-1996 1992 - 1996 Honda Prelude Si vtec O.E. Cal. Front Brake kit 29-516C $469.00
Honda Prelude all 1997-2001 1997 - 2001 Honda Prelude O.E. Cal. Front Brake kit 29-519C $469.00
Honda Prelude 1997-2001 1997 - 2001 Honda Prelude O.E. Cal. Rear Brake kit 29-625C $474.00
Mitsubishi Eclipse 1995-1999 1995-1999 Front Kit; FWD Turbo Eclipse 29-560 $398.00
Mitsubishi Eclipse 1995-1999 1995-1999 Front Kit; AWD Turbo Eclipse 29-561 $398.00
Mitsubishi Eclipse 2000-2002 2000-2002 FWD Eclipse 4cyl. 29-562 $418.00
Mitsubishi Eclipse 2000-2002 2000-2002 FWD Eclipse V6 29-563 $418.00
Mitsubishi Eclipse 1989-1994 1989-1994 Front Kit; AWD Turbo Eclipse 29-565 $398.00
Mitsubishi Eclipse 1995-1999 1995-1999 Rear Kit; Turbo Eclipse 29-630 $261.00
Mitsubishi Eclipse 2000-2002 2000-2002 Rear Kit; Eclipse V6 GT 29-630 $261.00
Mitsubishi Eclipse 1989-1994 1989-1994 Rear Kit; Turbo Eclipse 29-631 $286.00
Subaru WRX 2002-2003 2002 - 2003 Subaru Impreza WRX O.E. Cal. Front Brake kit 29-771BL $443.00
Subaru WRX 2002-2003 2002 - 2003 Subaru Impreza WRX O.E. Cal. Rear Brake kit 29-971BL $409.00
Toyota Celica GTS 2000-2003 2000 - 2003 Toyota Celica GTS O.E. Cal. Front Brake kit 29-540C $535.00
Toyota Celica GT 2000-2003 2000 - 2003 Toyota Celica GT O.E. Cal. Front Brake kit 29-542C $472.00
Toyota Celica GTS 2000-2003 2000 - 2003 Toyota Celica GTS (1 pc. Rotor) O.E. Cal. Rear Brake kit 29-610 $353.00
Toyota Corolla all 2003-2003 2003 Toyota Corolla O.E. Cal. Front Brake kit 29-540C $535.00
Toyota Matrix XRS 2003-2003 2003 Toyota Matrix XRS O.E. Cal. Rear Brake kit 29-610 $353.00
Toyota Matrix XRS 2003-2003 2003 Toyota Matrix XRS O.E. Cal. Front Brake kit 29-540C $535.00
Free shipping
Use coupon code HT5D for 5% off the prices above!
http://www.prostreetonline.com...grade
Free shipping
***AKA DREMAN***
How much can you get the the following below whats your best price since the price below was a few months back.
Illusion-Lighting
07-04-2003 08:35 PM
acuracy
03-26-2003 06:55 AM
acuracy
03-26-2003 06:54 AM
