Clutch Masters Clutches - 5% off!
HAN Approved Vendor
If you are looking for the best performing, highest quality clutches available, then Clutch Masters is what you have been looking for. What makes Clutch Masters different? It starts with a 20-thousandths stainless steel backing on the backside of the friction material. This helps to transfer heat from the lining to minimize clutch fade and ensure consistent performance. From there, they use a modified fulcrum point to increase pressure on the disc but without a substantial increase in pedal pressure as seen with other clutch brands. This is also important in protecting against the destruction of the crankshaft from excessive pressure on the thrust bearing which can happen when the pedal pressure is excessive. Some Extreme duty clutches can push the crankshaft a few thousandths of an inch forward when the clutch is depressed. This is not good at 8000 RPM. Lastly, the pressure plate utilizes a ductile iron casting which gives a much higher burst strength than other grey-iron castings. This gives you the peace of mind that the clutch will not be riding in the seat with you under high rpm use.
Application list:
Acura ClutchMasters Clutches
Audi ClutchMasters Clutches
BMW ClutchMasters Clutches
Chevrolet ClutchMasters Clutches
Chrysler ClutchMasters Clutches
Dodge ClutchMasters Clutches
Ford ClutchMasters Clutches
Geo ClutchMasters Clutches
Honda ClutchMasters Clutches
Hyundai ClutchMasters Clutches
Infiniti ClutchMasters Clutches
Isuzu ClutchMasters Clutches
Lexus ClutchMasters Clutches
Mazda ClutchMasters Clutches
Mercury ClutchMasters Clutches
Mitsubishi ClutchMasters Clutches
Nissan ClutchMasters Clutches
Pontiac ClutchMasters Clutches
Saturn ClutchMasters Clutches
Subaru ClutchMasters Clutches
Suzuki ClutchMasters Clutches
Toyota ClutchMasters Clutches
Volkswagen ClutchMasters Clutches
http://www.prostreetonline.com...tches
Use coupon code HAN5D for 5% off
FREE SHIPPING
bboy Wesley West
hmm, with the discount (exedy20d) 220 bucks for an exedy aint too shabby. i was wondering if exedy came with warranty. also another question, the clutch for my car is a f22a4 (part #08805) but it says it also fits f23's..so it will still fit my car?
