Coupling
HAN Approved Vendor
Coupling
Cant join 2 different pipe sizes? Tired of stacking coupling inside of each other? Use these connecting hoses with our T-Bolt clamps making them unblowable under any level of BOOST!
We have high quality, hi-temp, turbo connectors made of reinforced mutli-layer silicone. Do not settle for cheaper rubber connectors that fall apart in the heat. Our handwrapped silicone connectors will last for years to come. The gloss finish on our connectors makes them look new every time you clean them.
Specify color when ordering in Special Instructions. Available in black, red and blue
Silicone Transition 3'' to 4'' Connector PSI-SIL-201 $29.99
Silicone Transition 3'' to 3.5'' Connector PSI-SIL-202 $29.99
Silicone Transition 2.75'' to 3'' Connector PSI-SIL-203 $32.99
Silicone Transition 2.5'' to 3'' Connector PSI-SIL-204 $32.99
Silicone Transition 2.5'' to 2.75'' Connector PSI-SIL-205 $32.99
Silicone Transition 2.25'' to 3'' Connector PSI-SIL-206 $32.99
Silicone Transition 2.25'' to 2.75'' Connector PSI-SIL-207 $32.99
Silicone Transition 2'' to 3'' Connector PSI-SIL-208 $32.99
Silicone Transition 2'' to 2.5'' Connector PSI-SIL-209 $32.99
Silicone Transition 2'' to 2.25'' Connector PSI-SIL-210 $32.99
Silicone Transition 2'' to 2.75'' Connector PSI-SIL-211 $32.99
Silicone Transition 2.25'' to 2.5'' Connector PSI-SIL-212 $32.99
Click here to order:
http://www.prostreetonline.com...plers
Click here for all of our coupling:
eclipse spanker
12
11-20-2010 09:46 AM
