Tein Coilovers and STech Springs - Free Shipping
HAN Approved Vendor
TEIN Type Basic Coilovers
Starting at 725 shipped - TEIN's Type BASIC damper is for the driver that is seeking high performance with a reasonable price. Compared to the ''sleeve type'' coil over, the Type Basic has a more exclusive set up for a better balance of suspension travel and damping force.
Contents of damper kit :
Height Adjustable shock absorber x4, Main spring x4
Lower spring seat x4, Seat lock x4, Thrust washer x4
Bump rubber x4, Dust cover x4
Hook spanner x2, Instruction manual
Installation Time : 3 +/- hours
Click here to order: http://www.prostreetonline.com...overs
TEIN Type SS Coilovers
From 988 shipped - Coilovers designed with greater performance to satisfy all your driving demands for weekend racing and/or daily driving use. The discomfort caused by uneven roads or bumpes are eliminated on daily street use. For race use the ride height adjustable system enables you to adjust ride height and 16 levels of damping force. You can set your vehicle to meet all situations! Kit includes: 4 x adj. shock absorbers, 4 x main spring, 4x lower spring seat, 4 x seat lock, 4 x thrust washer, 4x bump rubber, 4 x dust cover, 2x hook spanner, and instruction manual.
TEIN Type HA Coilovers
From $1029 shipped - TEIN's Type HA coilovers represents the acceleration of your driving pleasure, 16 levels of adjustment, the Type HA Damper brings N1 style endurance racing to an affordable level. In addition to the basic function of the Type HR Damper, TEIN has added damping level adjustments. The variety of so much different damping effect is able to cover all setting range needed from soft (a degree of your vehicle's original damper) to hard (stiff as the N1 endurance race car) in 16 levels.
Full-length adjustment and height adjustment for separate setting of the height and spring preload.
16 levels of damping force adjustment (compression and rebound together).
Teflon coating for rust prevention.
Newly designed spring seat and spring seat lock for easy height adjusting.
Helper springs are included in this kit
TEIN Type Flex Coilovers
From 1372 shipped - TEIN's Type FLEX damper kit was designed to provide driving comfort and sports performance with its full-length adjustment system. They have incorporated separate height and preload adjustments, which allows you to have various set-ups to meet different road conditions. The FLEX Damper kit includes pillow ball upper mounts and is compatible with the EDFC, for maximum performance for the streets.
Pillow ball upper mounts are included.
Compatible with EDFC.
TEIN STech Lowering Springs
From 170 shipped - TEIN S.TECH Spring is an excellent step towards suspension tuning.These springs offer approximately a 1.5 inch drop for a more aggressive appearance. Comes with a 1 year limited warranty. Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects.
One year limited warranty.
High-grade material adapted to improve guaranteed satisfaction.
Rubber spring protector sheet to prevent noise (most applications).
Click here to order: http://www.prostreetonline.com...rings
HAN Approved Vendor
