Guage cluster lights in different colors
Old 01-27-2004 | 10:10 AM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
Default Guage cluster lights in different colors
I don't want to change the guage cluster, cuz I'm happy the way it is. But I wanted to add or change the bulb that illuminates the guages to a colored on or a black light. Anyone know where to get bulbs like this?
Old 01-27-2004 | 11:10 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
real black lights are fluorescent...so no you cant do that
You could rig a mini black light to the top of the cluster (maybe on top/behind the surrounding bezel and cut a hole). That would enable you to illuminate the faces, as long as you took out all the bulbs in the cluster itself
Old 01-27-2004 | 12:01 PM
ragerized's Avatar
ragerized
dc4 ownerages
ric0r? :chuckles:
actually, you could probably get some flourescent paint and paint the front and back. maybe if you put the black light in the back, you could light them up like that? or, like he said, custom mount a blacklight in up in there.
Old 01-27-2004 | 01:47 PM
Grifter's Avatar
Grifter
Originally posted by 137
This post was originally made on clubsi.com by neonoodle.
Anyways this is how I changed the color of my climate control. I used LED's because it was the only pure blue light bulb i could find. Plus when installed correctly they should last approx 100,000 hours, never fade in color and stay cool to the touch. I've re-done the lights in my climate control 6 times so far with many diffrent methods and setups.. This should be the very last time I mess with the lights in there. It came out by far the brightest, clearest and evenly lit.
I wouldn't suggest trying to do this unless you have some experience with electronics and soldering. You don't need much but it'll help a lot. Set aside a good number of hours if you plan to do this.
Here's what you Need....
(most of these things can be picked up from Radio Shack but the LEDs came from http://www.superbrightleds.com/)
Philips screw driver
Small standard screw driver (if you don't have finger nails)
Wire cutters/Stripper(scissors and teeth work but takes some practice)
Needle Nose Pliers
Soldering Iorn
Solder
Some thin copper wire in 2 colors
(15) 3mm Gallium Nitrate(GaN) Light Emitting Dioed(LED)s (3.5V 20mA)
(5) 100ohm 1/4 watt resistors
Heat shrink tubing (or electrical tape)
Krazy Glue
Scotch Tape
GooGone (or any other gentle glue removing agent)
Optional: 12V Power source (HIGHLY RECCOMENDED)
Here's what you do.....
First Remove the Climate control/radio unit from the car...
To do this you need to remove the drivers side lower dash..or part of it at least.. It's held on my the 3 screws circled in red and 3 clips where the yellow X's are.
It's easier if you remove the entire panel but I only removed the screw on the right side and pulled out the clip above it. The panel was flexable enough to get to the screws I needed.
Open the glove box and now you can get to all 6 screws that hold the center lower dash cover on.
(circled in red)
If you're having trouble accessing the screws on the glove box side you can drop the glove box down by pushing in on both sides at the top untill the stopper can squeeze by.
Once all the screws are removed pull the center panel out and disconnect the power outlet (pull black plug out of back of panel.)
Once you have the panel out you can now access the 4 screws that hold the radio/cc unit in place. (red X's)
After you remove them you should be able to pull or push (from behind) the unit out. It is held in by sevral clips so it takes some force.
Disconnect all the harness's in the back (you may have to reach up from underneeth to disconnect the radio harness) and take the unit inside the house with you.
Next you remove the knob section from unit.
After you remove the 5 screws (circled in red) and disconnect the harness to the 3 lower buttons you can push the section out the back.
Now you have this.. remove the 2 stock light bulbs(circled in red) by inserting something flat into the slot and turning it untill it pops out.
Then remove the 3 screws that holds the gray section to the white section and lift up the clips (This is where you need fingernails or a small flat screwdriver.) and pull them apart.. It will then look like this...(without as much wires)
Disconnect the two harnesses(circled in red) so you can put the gray section on the side for the time being..
remove the screw that holds this circut board(for the stock lights) down and remove it.. Next cut off the connector and wires at the side of the light circut board so you have just this
Now just pull out all 3 knobs and then seprate the black face plate (A) from the white section (C). Yourse won't have all that LED's/Glue/&Tape in it..instead pice (B) will be clipped in there.. Remove part B and then look at part A from behind like in the picture. You'll notice that the white part is gray/black/blue with 3 little round silver clips on pegs. This is a plastic filter to even out the stock lights that is glued to the face. Rip the clips off with your needle nose pliers and then pry up a corner with your nail or anything.. just try not to damage the face.. Once you have the clips off and a corner up you can slowly pull the filter off.. Once it's off completely there'll be a lot of gooey glue stuff.. remove the residue with your GooGone and clean it up nice and good.
This is where I determined how far apart I should place my LED chain.
I twisted the legs together and solderd them. The polarity of the legs is VERY important. I labeld it on the picture but if you're having a hard time reading it it goes...
[+LED-][+LED-][+LED-][-LED+][-LED+][-LED+]
Then I solderd on the resistors needed to cut down the car's +12V to something the LEDs can use. Because of the number and type of LEDs I used I needed a 100ohm resistor for each circut of 3(one on each side of the 2chains of 6 and one for the chain of 3). The resistors are circled in yellow and the polarity of the half segment is shown.
Next I solderd on the wires and put heat shrink tubing over connections that might touch another.
The gray wires with a black stripe are the positive wires.. the Blue wires are negative.. If you notice the ground wire for the 6 LED segments are attached between the 3rd & 4th LED where the two Negative Leads meet.
[+resistor][+LED-][+LED-][+LED-][ground(-) wire][-LED+][-LED+][-LED+][resistor+]
As you can see I put the LED segments onto the unit. I curved them to fit and made the LEDs face the center NOT UP. they are very very slightly angled up but not to where their beam will touch the face cover. If you face them up it will be too bright and you will be able to see the beam patters of the LEDs. (looks horrable don't try it!) after I placed them there I taped some of the wires and LEDs down with scotch tape.. If you notice the 3 LED segment is on the oppsite side. This is because the colored part of the climate control lets more light through so for it to look eaven the lights can't be right under it.
Next I attached the gray wires to the +12V of a computer power supply and blue to the ground of that power supply. I Tested to see if all the LEDs came on..then put the face back on and tested to see if the Light came out as desired. If it comes out extra bright in one spot that means and led is facing at that section of the face and you need to adjust the bulbs position. Try not to move the bulbs too much or the legs will break off making it useless.
Success! It looks white in the picture but in reality it is the bluest color you can get!
Now to secure everything. I opend the face back up...
And put a few drops of crazy glue down to almost every part that touched the back..and let it dry for a good while.. once everything was well stuck in place I put the face back on and tested one last time.
Now all you do is eaven out the diffrent wire lengths and solder them together. (i bound them together with heat shrink tubing) Then Solder the positve wires to the red wire of the connector you cut off and the negative wires to the black wire on that connector..
Then just plug the two connectors into the circut board on the gray section and put everything back together the just like how you took it apart. And you're done.. once it's all back in turn your headlights on and enjoy
The lights will go on and off with your headlights and can be dimmed with your factory dimmer knob
The following errors occurred when this message was submitted:
The message you have entered is too short. Please lengthen your message to at least 5 characters.
:ghey:
Old 01-27-2004 | 02:15 PM
lkailburn's Avatar
lkailburn
college kid
will that same process work for the dx model guage cluster and climate control? cuz i thought the lighting technique from an si was different than a dx?
Old 01-27-2004 | 02:39 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
dam grifter, you have some of the best posts... always from other forums tho. :thinking:
:fawk:
Old 01-28-2004 | 04:44 PM
Grifter's Avatar
Grifter
sorry i didnt read the title carefully when i posted
the cluster is illuminated by two bulbs at the top
the si and jdm amber is a film behind the gauges but im not sure how that works yet
Old 01-28-2004 | 06:30 PM
Wharbone's Avatar
Wharbone
Here's a link to hondatech where someone painted the bulbs. It has lots of pictures
http://www.honda-tech.com/zerothread?id=661308
Old 01-31-2004 | 10:09 PM
chimchim's Avatar
chimchim
Originally Posted by ragerized
ric0r? :chuckles:
Yeah yeah, I knew that's what it sounds like. What I'm really going for (maybe I shoulda said this) is that new look the Acuras seem to have. I dunno how, but it's white illuminated plus somehow it's got a glowy feel to it. That same glowy feel of a black light... so I'm trying to see if I can achieve something like that.
Maybe I should go on an Acura forum to figure that part out... eh?
Old 02-01-2004 | 01:52 PM
iNteGraz92's Avatar
iNteGraz92
forever lurking
like the TL and TSX?
they use LEDs
jordan88
92+ Civic/EL & Del Sol
8
08-17-2003 03:56 PM
EddieK
5
05-23-2003 08:10 AM
Lemonhead
4
02-01-2003 08:37 PM
dliske
10
01-18-2003 06:38 PM
sngx83
11-25-2002 07:55 PM
Quick Reply: Guage cluster lights in different colors
