stock rim quesion?
stock rim quesion?
these are the stock 5 spoke rims.
I heve been looking in to getting a set however i keep getting different numbers about the rims. This is what im looking for and what numbers i fave found.
16"x6.5" rim size
38mm or 40mm or 55mm offset
5x114.3cm(4.5in) or 5x115cm bolt patern.
16lb weight
if you guys can confirm which numbers are correct that would be great.
16"x6.5" rim size
16lb weight
the diameter and weight are correct and i believe the offset is 38 mm but im not sure without my helms. the bolt pattern is 5 but again not sure about the size without the manual. ill look for you when i get back to school.
Bolt pattern is 5 on 114.3mm
Offset is 38mm
16 X 6.5 @ 16#
Offset is 38mm
16 X 6.5 @ 16#
