Maintanince Help???
Maintanince Help???
I have a 2004 RSX and on my cluster that dam SERVICE REQUIRED light came on!! I was just wonderin does anybody kno how i can take it off without having to go to the dealer???
read your manual... the light comes on at certain mileage points reminded you to do scheduled maintenence on your vehicle. 2 minutes of reading and you should be able to turn it off yourself. Generally people take it to the dealer for this maintenence but it should also tell you all the services that are performed at this mileage point. If this is not the case you obviously have a sensor that has is triggering this light and you'll need to take it in for service or go to autozone have them pull the code its throwing at you and fix whatever problem it might be.
damn guys.. all you have to do is push in your trip reset button for like 15 seconds with the car on ACC and then turn it on.. its not a pain in the ass at all.. and if this does not work for you.. kinda hard to explain.. seeing I have not done it for about 6 months... just call the dealer.. tell them you serviced the car yourself and the light just came on.. and they will be more then glad to tell you how to turn it off yourself..
