Programming Instructions for 03 Civic Si remotes?
Old 01-14-2005 | 10:43 AM
ThePartsYouNeed's Avatar
ThePartsYouNeed
Default Programming Instructions for 03 Civic Si remotes?
Hello,
Does anyone have confirmed programming instructions for the Si model?
There are the general instructions we have, which don't appear to be working. Does the Si use a different set?
do steps 1 - 12 on the same remote AT TIME OF PROGRAMMING BOTH REMOTES MUST BE PRESENT SINCE THEY WILL NOW BOTH BE HAVE TO REPROGRAM. the following steps 1-12 are done on a single remote step 13 is done on all remotes to be programmed upto 3 can be programmed
1) get into the car shut the doors and make sure they are unlocked
2) turn on the ignition (do not turn on the car just the ignition)
3) press the lock button on remote (turn to off )
4) turn key to the accessory ON position (your radio works in this mode)
5) turn on the ignition (do not turn on the car just the ignition)
6) press the lock button on remote (turn to off )
7) turn key to the accessory ON position (your radio works in this mode)
8) turn on the ignition (do not turn on the car just the ignition)
9) press the lock button on remote (turn to off )
10) turn key to the accessory ON position (your radio works in this mode)
11) turn on the ignition (do not turn on the car just the ignition)
12) press the lock button on the remote
the locks should chirp to indicate that programming mode was entered successfully
13) press the LOCK button on remote the doors should chirp again to confirm programming THIS STEP NEEDS TO BE DONE FOR EACH REMOTE
14) turn of the car fully and try locking/unlocking with remote
to turn on/off the chirping when locking/unlocking with remote do the following
press the trunk release button on the remote and hold it then while holding press the LOCK button on remote and hold it the led on the remote will flicker for about 1sec after it goes off release both buttons and test it the procedure for chirp on and chirp off is the same, this needs to be done on both remotes otherwise only the one programmed will allow chirping while the other will still be silent or viseversa
