SRS light stays on 02 RSX S
I went to the dealer because my SRS light was on. Now the dealer says the computer indicates the passenger airbag was deployed and the entire system must be replaced for $3,200. I was in a fender bender 13 months ago, but the light was not on then and has not been on since. Has anyone else experienced or heard of this? I have a 02 RSX type S. Any information would be appreciated.
i had a prob. with my '03 type s with the passenger airbag light coming on all the time. my girl put a neon light that plugs into the cig lighter spot, and finally the light just came on permanently. the dealership said that somehow the neon messed up some kind of sensor and they were going to have to replace the whole seat. they covered it under warranty, so i didnt have to worry about it.
are they saying you have to replace the seat, or every airbag and sensor?
They are saying I need to replace "parts of the system", not the seat and nor the airbags. I guess I should get more details. The dealer wants me to file an insurance claim. My insurance co. says I have not claim b/c there was no accident. I also have the Acura Care extended warranty. I may have to get the customer relations dept involved.
you should check if your seat belt works if it works and the SRS lights is on it might be your control module which is located under the driver seat that controls all of your air bags...dont know wat happen to your car but mine is on and it the control module for my car cause i fish tail and crash into a wall and my seat belt didnt work so i replace it then it works fine but the srs light is still on so my friend that is a mechanic told me that its my control module...... so just check that
If you have the extended warranty then it should be covered. Make a big fuss about it and they will cover it. After all, they aren't paying out of their pocket. It goes right to acura. I have had warranty issues and people didn't want to help out. Posting threads like this and getting people involved is what you sometimes have to do. If the air bag wasn't deployed then you should have no problem. Maybe even talk to a couple different dealers and call acura's customer relations department. Also, you might want to talk to the manager of the dealership where you bought your car. That is, if you bought it new.
Did You Pull Out The Fuse At All?i Pulled My Srs Fuse And After I Put It Back The Light Always Stayed On.if So....disconnect Your Negative Battery Terminal For 3 Minutes And Than Reconnect It.drive Around For A Few Hundred Miles And Se If It Comes Back On When The Computer Resets-peace
I knew I wasn't crazy !!!!!
Mine came on too....but it doesn't come on very often....and it doesn't stay on.....weird. I guess I can have them check it out regardless.
Jimmy
Team B.O.B.™ - Ballaz on a Budget
R.I.P Huan Vo 11-19-2008
Jimmy
