H22A Running Now, Few Questions
Old 12-20-2006, 09:08 AM
vstylest05
vstylest05's Avatar
Default H22A Running Now, Few Questions
Hey, Well I finally got the JDM H22A into my 1992 Prelude SI. Im currently running the H23 Tranny... Everything on my car is stock right now, But I'm going to get a couple of bolt-ons, just the I/H/C/E. Well on my SI Guage it said my redline was 6500 with the H23. Now that I have the H22 where is my redline at? Also, What kind of ECU should I get for my h22, because I didn't switch ECU's yet so VTEC is not working. If I get a chipped Spoon P13 ECU that says I can redline at 8500, Is that safe? I'm the type of driver that redlines for no reason.
Old 12-20-2006, 09:11 AM
F22B Prelude
Rachel Bilson
F22B Prelude's Avatar
DO NOT CHIP YOUR ECU PLZ
Redline is anywhere between 6800-7200
Just get a P13
Do you have the H22 Harness and dizzy?
Old 12-20-2006, 09:49 AM
vstylest05
vstylest05's Avatar
Why should I not chip my ecu... I was going to get one from phearable.net I heard that's a pretty good place. I heard it really helps your performance. And the other day, I maxed out 120, It wouldnt pass 120. Someone said I will free more horses with a chipped ecu that would let me redline higher and make my air/fuel ratio better. if i get a ecu from phearable.net it also has a CEL shiftlight and 2 stage launch. Hmm about your question F22, I dunno if I have the h22 harness but my car works perfectly with the h22 all I need to do now is get a VTEC ecu and hook up the vtec. I'm not sure if I got h22 dizzy or h23 dizzy how do i check and why does it matter? thanks
Old 12-20-2006, 10:00 AM
F22B Prelude
Rachel Bilson
You will see no gains unless you tune your car....an 8500 redline is pointless for an H22 unless its built heavily(pistons, head, so on)...Revving it that high will damage your motor
If your car runs and you have no check engine light then the harness and dizzy should be correct...just change the ECU and be careful with your car.
Old 12-20-2006, 10:08 AM
vstylest05
vstylest05's Avatar
where is my normal redline?
Old 12-20-2006, 10:18 AM
F22B Prelude
Rachel Bilson
If you have the P14 ECU still its at 6500
Old 12-21-2006, 07:22 AM
vstylest05
vstylest05's Avatar
Whats the best RPM to shift at for best performance. And how do I make it so my engine is able to rev to a high rpm safely which parts do i put in
Old 12-21-2006, 01:06 PM
Snoopy
been there done that
Snoopy's Avatar
you're the type of driver that blows his engine by doing so, then wonders wtf happened.
shift right before peak power starts to fall off. only way to determine where this is is on a dyno.
you need cams that will make power higher than stock, stiffer valvesprings, and titanium retainers.
Old 12-22-2006, 11:37 AM
WhiteNoiz
WhiteNoiz's Avatar
Default ??
If I were you, I would get 8500 rpm out of your head! Get your power with more mods. 8500 rpm in a H22a would be the end result of a lot of $ in mods (or the first step to blowing your engine hah), and by that time, you probably wouldnt need to rev that high to get the performance you want. If you try and get to 8500 without internals, better prepare another "buy me an engine" speech for dad. Do some research before you ruin that engine, H22a motors are nice, it would be a shame to blow it.
oh, and if you dont care about blowing it, I can give you my address to send me some free money.
Old 12-23-2006, 07:12 AM
mberndt
mberndt's Avatar
Ditto...
LOL, this guy is gonna blow his engine...
