Weird sound from engine...
Old 06-21-2005 | 06:19 PM
diamondsleeper's Avatar
diamondsleeper
1990 & 1991 Si 2.05
OK I no longer believe its the clutch. It might be a bearing in one of the components like the alternator or power steering pump. Could be any one of the rotating components. Don't believe its internal to the engine. Might even be the idler/tesioner for the timing belt. Or even the water pump.
Old 06-22-2005 | 07:54 AM
katana62678's Avatar
katana62678
I had this sound in my old 92 accord, I was told it could possibly be a transmission bearing ??? But it was about that time when I traded it in without fixing it to get the 01 Lude.
Old 06-22-2005 | 11:09 AM
mtbprelude's Avatar
mtbprelude
RIGHT Wheel Drive!!!!
Which side of the engine bay is it coming from?
It may also be the AC.
Old 06-23-2005 | 08:47 PM
foot's Avatar
foot
If it is only in one small RPM range in all gears then it is probably not your transmission ( can't be certain through a message board ). The AC clutch is a possibility. Almost impossible to diagnose without being able to drive the vehicle.
