shrinking gas tank?
Old 12-16-2004 | 04:52 PM
preluder1's Avatar
preluder1
Default shrinking gas tank?
My recently purchased '89 Si seems to run out of gas while still showing 20 - 25 % in the tank. It will only accept about 10 gallons, though it should hold close to 16. I can't see any damage to the tank exterior, and the fuel pump and plumbing looks OK, too.
Anyone else have similar problems?
Old 01-01-2005 | 04:07 PM
preluder1's Avatar
preluder1
Default gas tank problem
I found the problem! The fuel pickup tube/screen had come off the fuel pump, so it wasn't drawing from the tank bottom. I added a polyethylene tube (from local hardware store) to the pump, slipped the old screen over it, and reinstalled the assembly in the tank. I was able to start the car with only a few gallons in the tank, which was indicating empty.
