weird engine noises!!!!
Old 12-03-2004 | 06:24 PM
yankee81116's Avatar
yankee81116
Default weird engine noises!!!!
i have a slight tapping noises when im idling----could that mean its time for a valve adjustment...also sometimes when i rev i get a whistling sound....i thought it was the stock airbox but then i put in my v2 and the damn noise is still there...sometimes it goes away but it always comes back. its a '00 5spd by the way
Old 12-03-2004 | 08:19 PM
SamuraiBill's Avatar
SamuraiBill
I has similar problem and it was the timing belt and tensioner. It was expensive fix.
Old 12-04-2004 | 07:44 AM
yankee81116
oh well it cant be my timing belt or tensioner cuz i switched them like 1000 miles ago
Old 12-04-2004 | 07:40 PM
ludeboom's Avatar
ludeboom
its not unheard of for the tbelt and tensioner to make some noise for the first oil change after they are replaced.
~kris
Old 12-04-2004 | 11:55 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Try adjusting the valves, they are easy to do anyway. Couldn't hurt.
As for the whistling, most aftermarket intakes whistle. It is strange that your stock airbox was whistling, did you remove the resonator?
Old 12-05-2004 | 10:26 AM
vtecguy2's Avatar
vtecguy2
is it like a hm....... noise??? only when ur idling../neutral??? i have the same problem trying to fix it right now... let me know if u got the problem fix or not... sorry to whore ur thread....
Old 12-05-2004 | 11:16 AM
yankee81116
no mine is like a very quiet tapping noise when im idling....when i pull the lude out of the garage, i get out to close the garage door, when i get back to the drivers door i can hear the tappin...gotta listen for it tho...so it could be only at first startup...it might go away after the engine warms up...gotta check...ill prob adjust my valves...but wat bothers me more is the damn whistling...i hate it...any ideas wat it could be??? i did remove the resonator
Old 12-07-2004 | 05:43 AM
raykan's Avatar
raykan
it's your timing belt...it's just tight, it will go away slowly (whistling sound I mean)
Old 12-07-2004 | 01:19 PM
ludeboom's Avatar
ludeboom
the tapping noise is 90% chance of being your valves, if it increases with RPM and turns into more of a banging then its one of your CR bearings failing...most likely your valve lash needs to be adjusted. I bought the special tool from snap-on to hold the adjustment while tightening the locknut.
<edit>
http://buy1.snapon.com/catalog/item....store&tool=all
</edit>
~kris
Old 12-07-2004 | 03:16 PM
yankee81116
well my tapping noise goes away the second i touch the accelerator.....so i guess i got some valve adjusting to be done....thanks alot guys
