weird engine noises!!!!
Old 02-02-2005 | 09:41 PM
ludeboom's Avatar
ludeboom
worst case: timing belt issue
best case: loose valve lash on at least one valve rocker
maybe a video or audio of the noise would help
~kris
Old 02-06-2005 | 07:18 PM
BlackShLude's Avatar
BlackShLude
i get the whine too brother after honda di my timing belt, i think the auto tensioner sucks to be honest.
Old 02-10-2005 | 08:36 PM
typeSHpapi's Avatar
typeSHpapi
can someone tell me how to attach a video on the post... i'm trying to post a audio/video of the noise in my car to see if someone can diagnose my problem. thanks
Old 02-11-2005 | 01:42 AM
Synthead's Avatar
Synthead
I had that problem once. It was a rock stuck in the guard for my cat ... lol. Banged it with the jack wrench and it was just peachy afterwards.
Old 02-11-2005 | 03:58 PM
monkey's Avatar
monkey
#212
Originally Posted by typeSHpapi
yeah... about the tappin noise, i have it too... but with my car it began after a NASTY miss-shift. i dropped it from 3rd at 8k rpm to 2nd! DUMB ASS!!.... right after i reacted and took it out of 2nd, and the car idled down... it turned off on me... it's had the tappind ever since.. it has turned off on me a couple of times while at a red light, and the tappin only seems to get bad while idling in colder weather.. i live in miami, so right now the weather is cold one day and hot the other.. that's how i noticed.... so you guys think i bent a valve.. or what?
when you misshift and get high enough over redline, you generally F your valves. and i'm willing to bet that you've got at least 1 bent valve. check your compression. hopefully nothing's wrong with anything else, because replacing the valvetrain will be expensive enough by itself.
Old 02-11-2005 | 09:09 PM
yankee81116's Avatar
yankee81116
i get like a whistling noise from 1k rpm to 3k rpm....it might go higher but i cant hear it cuz the intake really roars after 3k.....when i put my a/c on im pretty sure it gets worse....im thinkin its a vacuum line...any ideas...this isnt the whine from the timing belt i was talkin bout b4...that noise is gone.....this is more of a whistle....really aggrevating....any suggestions???
Old 02-13-2005 | 08:06 AM
yankee81116
i found out wat it was.......my ground for my amps was no good.....radio off--> no whistle....radio on-->whistle bingo!!!
Old 02-13-2005 | 02:53 PM
typeSHpapi's Avatar
typeSHpapi
