weird engine noises!!!!
Originally Posted by JL95AccorD
51 dollars for that tool?! A simple 10 mm wrench a screwdriver does the same exact job, and everyone has a set of them.
this tool allows u to hold the screw where u want it and then sock the locknut down, then you can throw the TQ wrench on there and torque the locknut to spec. that is what i do
~kris
yeah... about the tappin noise, i have it too... but with my car it began after a NASTY miss-shift. i dropped it from 3rd at 8k rpm to 2nd! DUMB ASS!!.... right after i reacted and took it out of 2nd, and the car idled down... it turned off on me... it's had the tappind ever since.. it has turned off on me a couple of times while at a red light, and the tappin only seems to get bad while idling in colder weather.. i live in miami, so right now the weather is cold one day and hot the other.. that's how i noticed.... so you guys think i bent a valve.. or what?
all ya need to do is a valve adjustment....you can do it urself....i did it like 500 miles ago...take about 1 hr to 2 hrs depending if you have done it before.....here is one walk thru...im sure there r more out there......
http://www.tsys07804.pwp.blueyonder....adjustment.htm
Im getting like a rubbing noise that seems to be coming from my timing belt......its not like a constant noise...its like noise.... 1/2 sec no noise.....noise..... 1/2 sec no noise...etc. Im pretty sure its comin from my timing belt....I had it changed about 1000k ago...noise started about a week or two ago....i was giving it some time thinkin it might go away but it didnt.....sometimes i get the noise sometimes i dont.....when i tap the gas the noise goes away....maybe cuz its cold out now???
sorry guys, i checked my engine with a feeler gauge and everything seems to be ok.... so doing a valve adjustment doesn't look like it'll fix the broblem... anyone has any more sudgestions as to what can be wrong with my car... sorry if i find too lazy to take it to a mechanic. i havent had anytime lately, i barely have time to write this let alone go to a mechanic.
