1985 lude help
Old 09-10-2004 | 09:02 PM
hanky42's Avatar
hanky42
Default 1985 lude help
hi im new to this forum but i just bought a 1985 dc lude and i was woundering what gen it was and i need a fuel/carb diagrams for repairing them i think the head gasket is blown so i gonna check the oil for water and the water for oil the check the compression. if you guys could get them diagrams i would be so happy. thanks also what motor is in it and what motor is in a 1987 fi lude 2.0 si
Old 09-16-2004 | 10:02 PM
sleepersol's Avatar
sleepersol
Not sure how much this will help but it is a second gen. It might be a A series motor but I'm not sure about the codes earlier than '88. The '87 might be a b20a. Look on the motor. Honda usually places the engine code in the front of the motor (down near the exhaust manifold). You can also try the forums on WWW.HPOA.ORG
Old 09-16-2004 | 11:54 PM
Kaspin's Avatar
Kaspin
1991 Prelude Si 4WS
It's a 2nd Generation, and you have an ET2 motor (was renamed to A18A1 in '87). The 2.0Si has a BT or A20A3, which is also found in the 86-89 Accord Fuel Injected models.
In Japan (and a couple other countries) there was a Dual Cam B20A available for the 2.0Si's (it's different from the B20A's from the 88-91 3rd gens)
