What am I doing wrong?
Old 11-20-2004 | 09:49 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Default What am I doing wrong?
I tried to get this picture to look better, but I keep doing something wrong. I wanted the snow to look crisper, but my car keeps getting darker?
File Type: jpg
Autocross Help Page
Old 11-21-2004 | 02:40 PM
Wharbone's Avatar
Wharbone
I would select the car with the polygonal lasso tool. Then under "Select" hit "Inverse".
Now you can adjust color, contrast, etc. without the part you selected. I also lightened your car slightly.
This was just a quick job. It can look much better.
edit: How do you make the attatched image full size?
File Type: jpg
Old 11-21-2004 | 08:02 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
you've been a member this long and don't know how to put a full size image instead of just attaching it?
:ban:
Old 11-22-2004 | 12:52 PM
Wharbone's Avatar
Wharbone
:ban:
I know how to use we todd and other services, but don't know how to make attatched files also show up as full size.
edit: nevermind, figured it out.
Old 11-22-2004 | 02:12 PM
SWOOSHER21's Avatar
SWOOSHER21
Fight Rice
is this what you are looking for. its kinda hard to work with 72 dpi, but i tried.
Old 11-22-2004 | 02:35 PM
CivicSiRacer
Wow that's great. But the color of my car is a bit dark.
Autocross Help Page
Old 11-22-2004 | 06:54 PM
SWOOSHER21's Avatar
SWOOSHER21
Fight Rice
thats what happens when the car is kinda fuzzy to begin with (low resolution and a bit over exposed). in your pic, the car color isnt very saturated. i tried to help it out a it, but like i said, its hard with the low resolution. there isnt enough digital data to keep everything detailed and clear. i could probably make it work if i wanted to sit an play with it for awhile.
Old 11-22-2004 | 08:05 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
try using the shadow/highlight adjustments in PS CS. That should help. If you don't want anything to change on your car, try cutting it out as mentioned above. Finally, you could also get a lot out of adjusting the levels, but it will make changes to the look of the car as well if if is not copied ot another layer.
hih Mike.
Old 11-22-2004 | 08:11 PM
westcoaststyle
done with shadow/highlight.
Made the car a bit brighter/clearer actually.
Old 11-22-2004 | 08:17 PM
westcoaststyle
A bit more tweaking with shadow/highlight:
