Golden Eagle Cam Gears Fuel Rails Oil Feeds Block Guards & Intake Manifolds
We are proud to be the first shop in the country to finish out buy in with Golden Eagle, the top sleeving and engine builders in the country and we thought we would pass the savings on to you thru some specials deals below
-Matt
Golden Eagle B-Series Block Guard
$99 Shipped
All Acura Integra DOHC All Honda Del Sol B16 DOHC 88-200 Honda Civic SOHC
Golden Eagle Adjustable Cam Gears
The 440 Adjustru ( Solid Face )
The E8S Adjustru ( Open Inner )
These gears have been tested on 850+ WHP motors and come with stailess steel bolts and washers that won't corrode. These gears are engineered to be the very best in style and performance. They will never slip and come with detailed instruction and torque specs!
Our new feature, the APLMIFIED SCALE, makes adjusting as easy as 1 2 3! This beautifully ENGRAVED feature will last as long as you own your car and not turn grey or brown like laser etching!! Siplmy rotate the outer until your desired degree lines up and voiala. perfect adjusting, everytime. Our gears feature hard anodized outers and inners in 2 different colors making it possible for you to choose from 4 different color combinations:
Black inner, Black outer.
Titanium inner, Titanium outer.
Black outer, Titanium inner.
Titanium outer, black inner.
We have all kinds of different gears that are to be available shortly.
Honda D-series, B-series, H-series, F-series and more
Acura B-series, K-series and moreGM Ecotec
Ford Focus and Duratec
Saturn 1.9L
Toyota Supra
Mitsubishi Eclipse
Subaru
and many more! Check them out as these will be the gears to have! Plus, you will not be able to beat the price!! Starting from $99.00 per gear!!!!! We will have all applications soon. Accords with in 2 weeks
440 Cam Gears For the GSR or Prelude are $189 Shipped Thats 2 Cam Gears
E8S Cam Gears for the GSR or Prelude $265 Shipped Thats 2 Cam Gears
New Applications will be listed at they become available
Golden Eagle Turbo Intake Manifold
QUICK FACTS:
· Impressive gains!
· Precision tapered runners
· Large plenum
· Complete bolt-on installation
· Dyno tested & race proven!
· Ladies Like big shiny items in your Engine Bay
CURRENT APPLICATIONS:
· DOHC Honda B16A or B17a
· DOHC Honda B18C or B18C1 or B18C5
· DOHC Honda H22A
$535 Shipped
Golden Eagle Vacuum Manifold
If any of your have decided that you need additional vacuum sources for things like boost controller, boost gauge, map sensor, waste gate, etc, then you know that it is a pain to do. Either you have to drill and tap your intake manifold ( this means removal of the manifold, performing the work, cleaning it out, then re-installing the intake manifold! Who wants to do that? ) or you have to use your existing vacuum hoses and TEE them off causing ugly spaghetti mess and sometimes an insufficient vacuum source.
Golden Eagle Mfg. has this problem licked with out Vacuum Manifold. This unit allows up to 6 additional vacuum supplies to be used without the headache. Simply figure out how many sources are needed, drill out the amount of ports needed ( very easy with a small drill and drill bit! ), clean, mount onto your firewall, connect the vacuum lines as needed, connect the Vacuum Manifold to your intake manifold with the supplied fittings, and your done. The best part is if you ever want to add, it is just as easy. Lets say you don't need that many later on, then simply use a pipe plug found at any local hardware store for a few cents. Comes with detailed instructions and all fitting to connect the Vacuum Manifold except the fitting for the intake.
O.K. look, here is how it works.
Your brake booster runs off of VACUUM, right?
Your wastegate runs off of PRESSURE.
Your boost controller runs off of PRESSURE.
Your map sensor just measures either/or!
Your fuel regulator adjusts to the pressure it sees.
Where is there going to be a vacuum or pressure drop? There won't be one! This just simplifies your set-up. That's all! Here is a basic schematic:
$45 Shipped
Golden Eagle Fuel Rails
these rails are top quality and come in three different colors:
Black
Titanium
Silver
Each fuel rail is satin finish and anodized then engraved for long lasting good look. These rails utilize o-ring fittings that ensure no leaks. You can buy either the AN adapter fittings or the stock "Banjo" fittings from us too. They have location for the stock regulator if needed and a port that can be used for a gauge or a pressure sending unit. These rails have the highest flow of ANY other fuel rails on the market.
Front of a B-series Black rail.
Showing the O-ring port in the rail!
Black and Titanium!! We also have silver.
We have many applications :
Acura/Honda B-series, H-series, D-series, GM Ecotec, Ford Duratec, Skyline, Focus, and many more coming soon.
$126 Shipped All Acura Integras All Honda Civics And Civic Si's All Honda Prelude If you use the stock fuel Pressure regulator a Banjo Adapter is needed $18
Vtec Conversion / Turbo Oil Feed
Well, here she is. This our VTEC Conversion Kit. A very easy and sanitary way to add a VTEC head to a non VTEC block. Uses filtered oil for supply. Also has AN fitting for the head ( the correct metric thread ) so there is no stripping threads. All you need is to get a line made whatever length you need! It also has a port that can be used or a filtered turbo oil supply or pressure gauge sensor. Accepts the stock filter. Installs in less than 10 minutes. No drilling or cutting required. This is a very simple install and is a must for LS/VTEC or CR-VTEC engines or for anyone with a turbo!!!
$99 Shipped
-Matt
$99 Shipped
Saturn 1.9L
Toyota Supra
Mitsubishi Eclipse
Subaru
QUICK FACTS:
· Impressive gains!
· Large plenum
· DOHC Honda H22A
$535 Shipped
$45 Shipped
Black
Titanium
Silver
$99 Shipped
got kind lost on ur prices how much for a fuel rail and fpr. for a b18a??? email me at ambition2020@aol.com
