Custom Built T3/T4 Turbocharger - Brand New
This is a BRAND NEW T3/T4 with V Trim Compressor and STG II Turbine housing and shaft.
Only been bolted on for mock up.
It was going on my girlfriends K20 RSX but she totaled the car last week so I'm selling all her turbo stuff.
Retails for almost $600.00
It is a custom built unit with the following TN and Garrett part numbers. V trim compressor wheel PN 20325, dry bearing housing PN 20327, Machined turbine housing and STG II Turbine shaft PN 30361.
It was specifically built for mild boost but is most efficient at 16 psi at 73%. It was VSR balanced and ULI verified for proper assembly.
This is not an Off-The-Shelf Garrett turbo you can buy, it is a custom built unit from a local turbo builder to me.
You can notice the picture of the center section. Look at the "A" stamping. That is the Air Research/Garrett branding logo.
Description:
* T3/T4 Turbo Unit supports roughly 369.24 HP - Most efficient at 16psi / 2.08 PR
* Standard Bearing
* .60 A/R T04B Compressor Housing
* V trim compressor option (50.8mm inducer/69.85mm exducer PN 20325)
* T3 .63 A/R STG II Turbine Housing and shaft (PN 30361)
* V-Band Discharge on gate with 2½ inch outlet
* Dry center section (Oil Only)
* Integral Wastegate
* Generic Volvo Style Actuator (7.25psi)
I will ship to US Lower 48 states free. HI, Canada and Alaska have a surcharge.
$325.00 Shipped to lower 48 PayPal Only
Please contact me with questions.
Thanks, Shawn
Description:
* Standard Bearing
Thanks, Shawn
