FS: Built B18A1 LS head and Built D16Y8 Motor..
FOR SALE:
B18A1 LS head:
-Ported and polished..
-3 angle valve job..30 degree backcut on the intake valves..
-resurfaced .010..
-new valve seals..
300.00..includes complete valvetrain (cams, followers, etc..)..
Built D16Y8 motor:
-Complete motor, or will separate head and block..
Block:
-Bored 20 over..
-Eagle Rods w/ARP rod bolts..
-SRP 10.5:1 pistons..
-Micropolished crankshaft..
-all new bearings and piston rings..
Head:
-3 angle valve job..30 degree back cut on intake valves..
-Comp cam valve springs (part #: 912-16)..
-Comp cam camshaft (part #: 59300) Intake lift= .455/.300/.310..Exhaust lift = .430..
-new valve seals..
-31.2 cc combustion chamber in head..
All together makes compression ratio 11.5:1 w/entire motor as built..
Entire motor 1500.00..block and head are currently separated, motor has 300 miles on it, never beaten..was still in break-in period..car was rear-ended..If separate, 1000.00 for block, 500.00 for head..
Have all paperwork for both LS Head and single cam motor..
Email me at: bluesiTYPER@aol.com ..
B18A1 LS head:
-resurfaced .010..
-new valve seals..
Built D16Y8 motor:
Block:
-Bored 20 over..
Head:
-new valve seals..
