FS: Si/Ex Trans (B000), ITR Suspension, and others (MI)
I'm located around Detroit, Michigan.
ITR Suspension SOLD
I have a complete set of ITR suspension. It comes assembled and ready to install. This is a great if you don't want to drop your car too low. I was going to swap it into my Integra but decided to stick with coilovers. I've never mounted these on the car so I can't really tell you how low it will go. I have an extra pair of rear JDM (not sure if it's also ITR) suspension along with another pair of rear ITR springs and front GSR springs.
So, you will get 2 ITR rear LCA, 6 Shocks/struts, top hats, and 10 springs. 6 of these are already assembled so all you have to do is unbolt yours and bolt these up.
AEM Belts for H/F Series
I have a PS and Alt belt by Bando. It came with the AEM pully set I had on my 93 Accord. The Accord has been long gone and I returned the pull and forgot the belts. These belt has never been used and is just sitting around.
Here's the part number.
4PK1100 & 6PK1140
Make offer
b18b block guard $50 New Never Used
EG Fuel pump $10
2G Splash guard. It's the pice off the bottom of the front bumper. This came off of a 95 TSI. $5
2G Rear gray inside tail light covers. $5
MAP $20
EG Gray Low Fuse Cover $5.00
CX/DX Cluster, 141550 Miles shown. $30
D Series AC Bracket $20 Each
D16z6 Power Stearing Bracket $15
OBD1 vtec ecu plugs, from an eg. $10
Rims
4 13" Stealies w/tires. Still holds air. $50
17" Chrome 4x100 & 4x114 $150
Manual Parts/Swap
Will sell everything here for $400 obo.
- D Series Si/Ex tranny (B000) $200
- Manual Starter $20
- Gas, Brake, & Clutch padel $70
- D Series Flywheel $15
- Clutch Master $20
- Clutch Slave, D Series $10
- Flex Clutch line $10
- D Series Shift Linkage $60
- Black Manual Shifter/cup holder $15
- Black e-brake cover $15
- (2)D Series Rear Tranny Bracket $15 Each
- D Series (1)Lower Manual & (1)Auto Tranny Bracket $20 Each
PICS UP, Just click on the link.
Everything in the pics is for sale.
http://www.imagestation.com/album/in...?id=2093733218
ITR Suspension SOLD
4PK1100 & 6PK1140
Make offer
EG Fuel pump $10
MAP $20
Rims
Manual Parts/Swap
- Clutch Master $20
