FS: GReddy E-manage Ultimate & Boomslang PnP Harness
I'm selling a GReddy E-manage Ultimate system that comes with a Boomslang plug and play harness. This system is better than any V-AFC as it controls ignition timing and fuel trim settings directly and this system includes data logging of almost any OBDII sensor. The system is complete and already setup for any 4cyl Honda with VTEC but can be setup for almost any car.
The Boomslang PnP harness is for OBDIIa found in Civics, 96-98 Integras, and all 5th Gen Preludes. This system is already setup and can be installed in around 15 minutes.
This system is perfect for anyone who wants to pass OBD SMOG or wants to keep their ATTS system or wants to tune their automatic.
GReddy E-manage & PnP harness & 6ft USB cable & A/F attachment: $625 shipped
Willing to separate the main unit out for $430 shipped.
- FUNCTIONS
Airflow Correction :
Airflow Adjustment Map / Airflow Output Map / Boost Limiter Cut Map / Anti-Engine Stall Map.
Injector Correction : Injector Adjustment Map x2 / Acceleration Injection Adjustment Map / Individual Cylinder Injection Adjustment / A/F Target Value Map / Vehicle Speed Correction Map, Coolant Temp Correction Map, Intake Air Temp Correction Map / Rev Limiter Cut
Ignition Adjustment : Ignition Correction Map x2 / Acceleration Ignition Map / Individual Cylinder Ignition ADJ Maps / Ignition Cut Feature / A/T Shift Compensation Feature
Others : External Output Map (VTEC) / NVCS Control Map / Analog Output Map / Idle Stabilization Map
- ADDITIONAL FUNCTIONS
Serial Port : External Data (such as GReddy Warning Meters & other future optional products) can be monitored and recorded in real time through a data link cable.
Switch Port : Data Logging & Ignition Cut features can be activated with the use of an optional Remote Switching System & Switching Harness
Option 1/2 : GReddy Pressure Sensor, GReddy Temp Sensor, A/F Input Harness, Multi Switching System Adaptor, External Switch & Factory Pressure Sensor.
If you have any questions feel free to PM me
- FUNCTIONS
