f/s pair of mmats amps 500.2
i am selling two Mmats amps one of the models is D 500.2 and the other is the SQ 4070. These are very good and powerful amps. All wires are included. Nothing is wrong with them. $400 shipped.
Here is the information for the D 500.2
• 500 W RMS 2 Ohm Mono
• Leading edge technology
• Efficiencies over 90%
• 4 AWG battery inputs
• Optimized for low impedance loads
• Dual MOSFET power supplies in the HC models
• 24db low pass Linkwitz-Riley infinitely variable filter
• Frequency Response(-3db) 10Hz to 230Hz
• Signal to Noise Ratio -92db A weighted
• Distortion@Rated Output < 0.1% THD+n
• Damping Factor@100Hz >125
• Input Sensitivity 150mV to 2.5Vrms
• Idle Current 1 amp
• Efficiency @ 1/3 power >72%
Here is the information for the SQ4070
Here is the information for the SQ 4070 amp:
Specifications
Key Features
Amplifier Type: Dual Channel
Bass Boost: With Bass Boost
Bridgable: Bridgable
Power Output
RMS Power at 4 Ohms: 70 W x 4
Performance
Bass Boost Frequency: 45 Hz
THD at Rated RMS Power: 0.05 %
Signal to Noise Ratio: 105 dB
Frequency Response: 10 Hz - 25000000 Hz
Other Features
MOSFET amp: Yes
Specifications
Key Features
Power Output
Performance
Other Features
MOSFET amp: Yes
