F/S: Action Clutch,ACT 12lb Flywheel,Jackson Racing Thermostat,Misc D/B Series Stuff
This is an unsprung 6-puck Action 1MD clutch for B series hydro trannies and a 12lb ACT Streetlite chromoly flywheel for any B series engine. Both clutch and flywheel have ~10k miles on them and are in good condition. Thowout bearing included with clutch, and pilot bearing included with flywheel, but you'll probably want to replace them. $200 for the clutch, and $150 for the flywheel, or $325 for both.
Thermostat and thermoswitch - SOLD
JDM LS/CRV P75-2 head - Head stamp says it's a 96. Came off a JDM B20B with ~30k miles on it. Good condition, what you see is what you get. Make an offer
OEM 99-00 Civic Si Airbox/Intake Arm - Good condition, comes with genuine Honda replacement filter. Make an offer
B&M fuel pressure gauge - no fittings, just the gauge, make an offer
Generic single bend short shifter - should fit Civics and Integras, comes with some hardware, but you might need some extra washers/spacers, also might need to replace/lube the bearings make an offer
OEM Rear LCA's - fit 96-00 Civics, make an offer
OEM springs - fit 92-00 Civics and 94-up Integras, make an offer
OEM Civic shifter arm - make an offer
D16Y8 starter motor - off a 97 EX MT, $50
D16Y8 Shift Linkage - comes with poly ES bushings, $30
D16Y8 oil pump - ~1000 miles on it, $30
D16Y8 internals - complete internals from my 97 shortblock, #3 piston has cracked ringlands, make me an offer
D16Y8 backup light switch - $15
D16Y8 crank pulleys - 2 available, make an offer
D16Y8/B18B engine mounts - D16Y8 AC mount, front tranny mount, upper tranny mount(on chassis), rear chassis mount, rear tranny bracket; LS front torque mounts(on chassis); make an offer an any or all
98 LS power steering pump, pulley, belt(not pictured because I have several belts lying around and I don't know which one it is), bracket - 60k miles, make an offer
98 LS clutch disc, pressure plate - Very low miles, a lot of meat left, make an offer
98 LS clutch slave cylinder with some brackets and lines - make an offer
98 LS flywheel - good condition, make an offer
98 LS fuel pump - 60k miles, make an offer
98 LS intake manifold bracket - make an offer
This is a brand new and never used Earl's -10 45 degree Swivel Seal hose end. It retails for about $24. Get it here for $18.
________________
Buyers pay shipping costs on all items, unless otherwise noted.
All parts listed are from a 97 Civic EX or 98 Integra LS, unless otherwise noted.
Email me(Chris) at inspyral@aol.com
I'm in San Jose, Cali.
________________
