im n so cal i need a water pump 89 rex si!!!!!
Old 08-26-2005 | 05:35 PM
jdmc-rex909's Avatar
jdmc-rex909
Default im n so cal i need a water pump 89 rex si!!!!!
i need a water pump sooo bad i have a crx si 1.6 zc vtec some one help please i need it asap if you pm me leave me your number ill call u or call me 9095393779 im Dre
Old 08-27-2005 | 07:03 AM
icyfingers's Avatar
icyfingers
Here's a Parts Interchange List i found online...
Engine Mounts:-----1988-91 CRX/Civic
Timing Belt:-----1988 Prelude 2.0
AC Compressor / Parts:-----1989-91 CRX/Civic
Throttle Body:-----1988-91 CRX/Civic
TPS:-----1988-91 CRX/Civic
ECU:-----1989-91 CRX/Civic Si, 88-89 Integra 5-spd, 89-91 ZC
Intake:-----1988-91 CRX/Civic
Headers/Exhaust Manifold-----88-91 CRX can be used port will not be perfect---Ideal is DC 86-89 Integra Top with 88-91 CRX downpipe---(I use port matched GUDE 4-1 Header)
Plug Wires:-----1986-89 Integra
Spark plugs:-----1986-89 Integra or 1988-91 CRX/Civic----- NGK BCPR6E-11
Distributor Cap:-----1988-91 CRX/Civic 1988 Integra
Distributor Rotor:-----1988-91 CRX/Civic 1988 Integra
Head Gasket:-----1988 Prelude
Intake Gasket:-----1988 Integra
Exhaust Gasket:-----1988 Integra
Water Pump:-----1989-91 CRX
Oil Filter:-----1988-89 Integra-----Fram PH3539A
Oil Pan Gasket:-----1988-91 CRX/Civic or 1986-89 Integra
Flywheel from 1989-91 CRX Si may be used
ZC Pressure Plate:-----1989 Civic DX
ZC Clutch Disk:-----1989 Civic DX
