WTB B series parts (LS)
Old 06-24-2005 | 07:36 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
Default WTB B series parts (LS)
EDIT***Stuff coming in!
This is the list I typed up for my build...which is why there are part numbers and prices
If there is something that you may have, but cant understand what I want, just pm me and I'll clarify.
Pending Parts Found:
Water: 6, 19s
Timing: 3, 7
Head Thermo:
Water Outlet:
19315-PR4-A01 COVER, WATER OUTLET $13.24 (Number 6 above)
Outlet Bolts:
95801-06030-08 BOLT, FLANGE (6X30) $0.12 qt. 2 (Number 19 above)
Head Crap:
Cover:
11820-PR4-A01 COVER, TIMING BELT MIDDLE $17.35 (Number 3 above)
Cover Seal:
11925-P30-000 SEAL A $3.56 (Number 7 above)
A/C Bracket (CR-V):
38930-P7J-000 BRACKET, COMPRESSOR $62.48 (OR DEL SOL)
B18b IM:
IACV:
Throttle Cable Bracket:
16411-P75-000 STAY, THROTTLE WIRE $6.52
Old 06-28-2005 | 10:08 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
I have an skunk 2 intake manifold for sale that will fit any non-vtec b-series head. 150.00. shipped.
Old 06-29-2005 | 02:33 AM
GReddyboy's Avatar
GReddyboy
I have a 99 si head that had a valve dropped, but it has all the keepers and most of the exhaust mani studs you need plus the water outlet with the bolt. its basically complete head without vtec solenoid, cams,im,and valve cover. I let it go for $50 picked up im located in northern cali..
Old 06-29-2005 | 09:49 PM
1fasthb's Avatar
1fasthb
Water Pump Acc:
Thermo Cover:
19311-P2T-000 COVER, THERMOSTAT $10.77 (Number 5 above)
Thermo Cover Bolts:
95701-06020-08 BOLT, FLANGE (6X20) $0.09 qt. 2 (Number 17 above)
Thermo Sensor:
37760-P00-004 SWITCH ASSY., THERMO (A-93) (UCHIYA) $27.68 (Number 11 above)
Head Thermo:
Thermo Unit:
37750-PH2-014 THERMO UNIT $23.27 (Number 10 above)
Water Outlet:
Outlet Bolts:
Head Crap:
Exhaust Manifold Stud:
90026-PE0-000 BOLT, STUD (8X37) $2.32
NEW Valve Keepers:
14781-PL2-004 COTTER, VALVE (SANKO) $1.70 qt. 32
Cover:
Cover Back:
11840-PR4-A00 COVER, TIMING BELT BACK $18.91 (Number 6 above)
Cover Bolt A:
90010-PR3-000 BOLT, TIMING BELT COVER $2.94 qt. 2 (Number 18 above)
Cover Seal:
Cover Bolts B:
90007-679-000 BOLT, TIMING BELT COVER A $2.63 qt. 7 (Number 17 above)
Back Seal:
11832-PR4-A00 RUBBER, R. BACK SEAL $20.16 (Number 5 above)
Oil Dip Stick:
15650-P3F-A00 DIPSTICK, OIL $13.26
A/C:
A/C Bracket (CR-V):
A/C Mount Bolts:
95801-10045-08 BOLT, FLANGE (10X45) $0.76 qt. 4
A/C Arm:
38941-P30-000 BRACKET, AIR CONDITIONER $24.91 (Number 11 above)
Bracket Bolt:
90054-P30-000 BOLT, SPECIAL (10X30) $3.00 (Number 15 above)
Bracket Bolt 2:
90086-PR3-000 BOLT, SOCKET (10X28) $3.69 (Number 16 above)
Pulley Collar:
38944-P2T-000 COLLAR, IDLE PULLEY $3.67 (Number 13 above)
Mount/Bracket:
Engine BRKT Bolt: (CR-V)
90009-PR3-000 BOLT B, MOUNTING BRACKET $2.51
Engine Side Mount (EM1):
11910-P30-000 BRACKET, ENGINE MOUNT $48.57
Rear Engine Bracket (EM1):
50827-S04-N10 BRACKET, RR. ENGINE MOUNTING $35.44
B18b IM:
IACV:
36450-P6T-S01 VALVE ASSY
Stay Brace:
17132-P75-000 STAY, IN. MANIFOLD $38.37 (Number 11 above)
Stay Bolt:
95701-08020-08 BOLT, FLANGE (8X20) $.52 qt. 4 (Number 24 above)
Stay Bolt 2:
93406-08016-08 BOLT-WASHER (8X16) $.70 (Number 19 above)
Valve Cover stuff:
Nut/Caps:
90213-PH3-000 NUT, CAP (6MM) (CHROME PLATED) $2.11 qt. 7
I have everything except for the crv a/c bracket, valve keepers, and the mount brackets. Make me a reasonable offer on everything else and we can go from there
Old 06-30-2005 | 01:33 PM
PDiggityDogg
I dont need an intake manifold
I am not anywhere near california, and b series vtec parts are different from ls (only thing that would fit is the exhaust stud)
How much for all of it (dont say reasonable offer - tell me what youre looking to get)
Old 07-05-2005 | 09:05 AM
IN VTEC's Avatar
IN VTEC
Here's what I've got:
Thermo Cover:
Thermo Cover Bolts:
95701-06020-08 BOLT, FLANGE (6X20) $0.09 qt. 2 of 2 (Number 17 above)
90026-PE0-000 BOLT, STUD (8X37) $2.32 1
Cover Bolt A:
90010-PR3-000 BOLT, TIMING BELT COVER $2.94 qt. 2 of 2 (Number 18 above)
Cover Bolts B:
90007-679-000 BOLT, TIMING BELT COVER A $2.63 qt. 5 of 7 (Number 17 above)
Back Seal:
Valve Cover stuff:
Nut/Caps:
90213-PH3-000 NUT, CAP (6MM) (CHROME PLATED) $2.11 qt. 4 of 7
Oil Dip Stick:
Total = $25 shipped (as long as you're in the lower 48)
Old 07-05-2005 | 10:30 AM
PDiggityDogg
Cool.
Forget the cover caps, since you dont have them all. So how about $22 shipped instead?
Snap some pics and send them to pmbritto@oakland.edu
I really need to be sure that the thermo cover is the right one, since some have the sensor in it, and some do not. (I need the exact same one as shown)
Old 07-08-2005 | 07:40 AM
PDiggityDogg
Up
