FS: BUILT H22a SWAP w/ everything. & Sleeved h22a Longblock + more
Gotta get rid of this stuff!!
NEW** If anyone wants to, i can switch blocks on the whole swap so that the sleeved block(11.5:1, eagle rods, balanced) in included in the swap instead of the type S bottom end
If you know how much it costed to sleeve the block, and include all the aftermarket pistons, rods and balance them. and how much it was for all the head parts and labor, and the DSS stage 2 axles and the header and all the stuff i have here, you would know how much of a deal this is. MUST SELL
PICS SOON AVAILABLE BY REQUEST
JDM H22a OBD1
Type S pistons 11:1
Skunk2 Stage2 cams, valves, valvesprings, retainers.
Skunk2 Camgears
Skunk2 valves
Honda valve guides
JDM Red valvecover
Head milled down, mild port on intake vortex area and valve inlets.
Cometics thin headgasket
New timing belt and tensioner (still auto)
Water pump(stock)
Adcco 11# flywheel
InLINE4 70mm TB
New distributer with external coil setup.
And some cam seals and other small things.
ECU- JDM P-13 Chipped with mugen program, vtec at 5000, and 8500 rev limiter
Dynoed 221 @ 8000 RPM
JDM LSD Transmission
ACT Extreme Presure plate and Street Disk clutch type.
New slave clyinder, clutch fork, and Throwout bearing.
Included in the swap
Drive Shaft Shop Stage 2 axles (1 boot torn, but still good(warrenty*))
Full wiring harness for 92-95(eg) civics OBD1
HASport Mount kit. BRAND NEW~!!! H22 - EG
Full shift linkage with 00 Prelude Shifter assembly and cables( brand new) Kit to fit with some mods, but will be airtight and shift short, has DCsport short shifter.
HEADER!! I have a Imagine engineering header that will come with the swap, good header, adds 20 hp over DC sport
DYNOED AT 221.7 on a mustang dyno!! 154 Ft.lbs(header)
With that said, im asking $3700 for the swap. Anyone with offers can contact me at H22atch69@aol.com. Trying not to ship, but will but you pay shipping.
H22a LONGBLOCK
JDM H22a
SLEEVED!!
Benson sleeves
J&E 11.5:1 Pistons
Eagle H-beam rods
balanced to 9,000 rpms
new Honda bearings.,
Ran for a good 4000 miles then wrecked the chasis so it was a loss, but i checked the motor the other day and it has no leaks, and it ran great!!! was in 4th gen lude. BTW it needed the head milled cause it was apparently leaking oil, and this was after the break in period, and the pistons and sleeves still looked good, so i knoiw it was done RIGHT!!
Asking $1700 for the longblock!!
These motors were my projects, unfortunately ive spent more money then i will be able to get back, so i will cut my losses
Like i said, i would preffer a pickup!!! But i will ship as long as shipping is paid for.
MORE STUFF
Fluidyne Half-rad for civics With FAL slimfan is red. Rad isnt damaged, but has been used. Fan runs but has some scratches $$500
IF YOU WANT TO LOOK AT THE STUFF, MAKE ARRANGEMENTS!!! EMAIL H22ATCH69@AOL.com
JDM H22a OBD1
Type S pistons 11:1
Skunk2 Camgears
Skunk2 valves
Honda valve guides
JDM Red valvecover
Water pump(stock)
Adcco 11# flywheel
InLINE4 70mm TB
H22a LONGBLOCK
JDM H22a
SLEEVED!!
Benson sleeves
J&E 11.5:1 Pistons
Eagle H-beam rods
MORE STUFF
I WILL SELL THE SWAP FOR $2300 dollars!!!
and the sleeved longblock for $1000
email me at h22atch69@aol.com
later
later
