FS: Lots of aftermarket, performance, and engine parts. SEVERAL PICTURES, ok for 56K
PLEASE CLICK ON THUMBNAILS TO VIEW LARGER PICTURES
Autometer 92-95 Civic Tach pod Includes Autometer 3094 Sports Comp tach with shift lite (not installed), 2 5/8 VDO oil pressure & water temp gauges. The tach is missing the "PUSH TO DISPLAY" button. This stuff is used less than 3 months. Paid over $300 for this stuff. SOLD
Blitz High-Pressure Radiator Cap Like new. SOLD
Crane Hi-6 Fireball Ignition and Coil Comes with an LX92 race coil. Both have less than 5K miles. Comes complete with all wires and a coil wire. SOLD
Comp Cams DOHC VTEC 57200 cams Stage 2 cams. Comes with beat up HP Racing gears. SOLD
1994 B18C1 High-Compression Short Block Has P30 pistons on shot-peened rods. New rings, bearings, water pump. Used for 5K miles after rebuild. SOLD
ARP Head Studs Torqued just once. SOLD
94 B18C1 head with Port Flow valve train Springs have less than 2500 miles on them. Has been recently rebuilt. Comes with stock GSR cams. Everything inside the valve cover is included. Cam and caps are not pictured. SOLD
GSR Valve springs and Retainers Have about 80K miles on them. SOLD
Skunk2 B18C1 Intake Manifold Manifold has less than 5K miles on it. Manifold is bare. All assessories and sensors are sold. SOLD
D16Z6 long block Mileage is unknown, but it visually looks to be around 100K miles. Look like it has its original timing belt and water pump. Needs bearings because I took them out and never put them back in. Does not include the injectors, because I took them. Oil pan is dent free. For the buyer, I can install an ACL bearing kit for an additional $85, a new OEM Honda timing belt for $50, a new water pump for $40. For just the head and block $275 plus shipping
Random Technology High-Flow Catalytic Converter for Integras All stainless steel. Direct bolt-on for Integras. Fits OBD1 and OBD2 cars. SOLD
Chipped P28 ECU Comes with three different chips. SOLD
Over-bored Throttle Body 65mm tapers down to 63mm. Not even 500 miles on this SOLD
Racing Hart CP-035 These are the real thing; forged and light as hell. Not that RH Evo or some cheap clone. And I still have the receipt for those that doubt. They are 3 years old. Only 16 weeks of use! The wheel and tires specs are as follows:
-16x7
-45mm offset
-4x100mm
-hub-centric rings for Civics and Integras, and whatever fits them.
-215-40-16 Toyo T1-S tires
-Wheel & tire weight about 26lbs
-McGard Cone Seat Spline Drive Lug Nuts in black are included
They are painted flat black. No scratches or anything like that. Do not bother low balling. $1300 obo
Racing Hart 3-piece C5
Real 3-piece wheel. These are not made anymore. These were over $3500 brand new. Two lips have very minor bends in them that are hardly noticeable. Finish of wheels and lips are excellent.
-19x8
-50mm offset
-4x114mm & 5x114mm
-235-35-19 Pirelli P7000 tires
$2500 obo
ACL Bearing kit for B18A, B18B, B20Z, B20B Includes main and rod bearings, and thrust washers. SOLD
1995 Acura Integra GSR engine harness. Uncut harness for OBD1. SOLD
CUSCO Type-RS 1.5 way LSD Fits all Pre 99 B16s transmissions and all LS transmissions, and 92-93 GSR transmissions. For 99-00 Si and 94+ GSR & ITR, you will need a smaller 4.4 ring gear. This is a brand new 1.5 way clutch type differential. SOLD
MINT B16 Valve Cover MINT condition. No Scratches. Looks brand new. SOLD
Please email me or send me a private message with offers, or post here if you have any questions.
-16x7
-45mm offset
-4x100mm
-19x8
-50mm offset
-4x114mm & 5x114mm
$2500 obo
Last edited by Smoothy; 06-22-2004 at 08:56 AM. Reason: Sold parts, removing them from the list
the bearings
hey, what do you know about these bearings? theyre new right? ive been looking at some... i dont wanna in any way flake on my engine, though. its all gonna be done right, which is why im leaning toward OEM products. i also loked at king bearings, which people didnt say anything bad about. but yeah, im interested, hit me up at cryptkeeper12384@hotmail.com and we can chat on aim or something, since email takes so damn long.
Tirod
News & Rumors Archives
31
03-03-2003 05:13 PM
jaje
07-11-2002 08:01 AM
