FS: ABIT IT7 MB w/P4 2.4B@3GHz + 512MB kingston DDR2700 + FREE 27gig
Hello, I am selling my p4@3GHz setup I've used for a year. I'm asking $350 for the bundle, CPU, memory, motherboard AND Western Digital 27Gig HardDrive. Insured shipping is included. (Westcoast USA only. Otherwise you pay for shipping.)
contact me here or at kotetu@hotmail.com and put "P4 BUNDLE" in the subject!
Here are the details:
ABIT IT7 - http://www.abit-usa.com/products/mb/...ies=1&model=33
This MB is very advanced. It has ten (10!!!) USB 2 ports, 3 firewire ports, and can connect 2(x2) normal IDE + 4(x2) ATA100 RAID for a total of 12 devices. This has built in AC97 audio, (Line-in,Center/Sub, Surround Spk, Front Spk ,Mic-in), with digital input capability. It also has a built in 10/100 LAN controller.
Basically, all you need is a good video card and you are good to go.
INTEL P4 2.4B -
Retail processor, successfully overclocked to :
2700 (150mhz x 18) - memory @ 300mhz, 2,2,2,5
2880 (160mhz x 18) - memory @ 320mhz, 2,3,3,6
3006 (167mhz x 18) - memory @ 250mhz, 2,2,2,5
I run it at 2880 generally. I found that there was little difference at 3006, probably because I had to turn on the 3/4 multiplier for the memory. However, all of these settings are very fast!
Kingston Valueram DDR2700 512MB CAS 2.5
This memory actually runs at cas 2 in the above settings, I didn't try to overclock the memory, just let the motherboard set it (setting is called "by speed")
Western Digital 27Gig 7200 RPM Enhanced IDE harddrive - what can I say? large capacity and never had any problems.
Disclaimer:
Overclocking puts these components at risk and out of warranty! Your mileage may vary depending on your cooling! I use an ALPHA cooler with a tube to bring fresh air to the cooler. This is NOT included in the sale. You will get the standard (very big) P4 cooler + some extra temperature monitoring case fans.
INTEL P4 2.4B -
Disclaimer:
