Alpine MRP-M350 mono amp
This unit has been used for only a month. It was installed underneath the trunk floor where the spare wheel is located. Looks and performs as if it is brand new since nobody and nothing ever came in contact with it.
Price: $125 and free shipping.
DETAILS
Thanks to impressive power output, affordable pricing, and exceptional reliability, Alpine's V-Power amps are consistently among our best-selling models. The MRP-M350 mono amplifier gives you awesome bang for your buck, and sports some "extras" that you'd usually find only on higher-priced amps!
Hook up the MRP-M350 to one 4-ohm sub, and you get 200 watts RMS; connect a second 4-ohm subwoofer and the power output increases to 350 watts! All that juice means that your subs won't just be loud, they'll sound clean and musical, too. A variable low-pass crossover lets you tune the output to match your particular sub setup.
The 15 Hz subsonic filter eliminates very low notes (those that are too low to hear) from your system, so your bass won't sound muddy. Plus, you'll want to take advantage of the BassEQ — an adjustable bass boost of up to 12 dB at 50 Hz! Speaker-level inputs allow you the flexibility to hook up the MRP-M350 to just about any system, and gold-plated terminals ensure that you get clean signal transfer both into and out of the amp.
Key Features:
200 watts RMS x 1 at 4 ohms
350 watts RMS x 1 at 2 ohms
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
MOSFET power supply
low-pass crossover, 50-200 Hz, 24 dB/octave
variable Bass EQ bass boost (0-12 dB at 50 Hz)
preamp- and speaker-level inputs
blue power LED
extra-large gold-plated terminals
9-3/16"W x 2-7/16"H x 9-9/16"D
1-year warranty
DETAILS
Key Features:
MOSFET power supply
blue power LED
1-year warranty
