D series stuff, supercharger, flywheel, gauges...
Jackson Racing Supercharger
-for a D series, some models you will need to upgrade the fuel rail (or modify your stock). Has aporox 2K miles on it. Comes with stock pulley and belt, as well as a 13.5 psi pulley with belt. Also included is the manifold gasket and throttle body gasket (both fel-pro).
MKIII Turbo Supra 440CC injectors
-injectors, comes with Honda resistor box as well.
Jackson Racing Fuel pump
-aprox 2K miles…comes with strainer etc.
Unorthodox 8lbs Flywheel
-for a d series, I believe it will fit all but a ZC? Which what I was told…
-Ventus HR II 205/40/17 tires
85% tread…
-Xbox about 2 months old. Comes with 2 controllers, a memory card, and all the necessary connection cables. Also has Amped Snowboarding, Sega GT 2002, NFL Blitz 2002 (FUN! Hehe) Mortal Kombat Deadly Alliance looking to get about $195-200 + shipping. SOLD
-99 Civic EX stock steelies, tires (75% tread left) 3 hubcaps! (comes with lugnuts!)
Make Offer (u pay the shipping) I'll try to get you a fourth hubcap if you'd like.
-Equuis Compression Tester, goes from 0-300 PSI or 0-2100 KPA. Pt# 3612 Unopened…somehow I got 2 of them?
-Auto Xray OBD II code reader. Used twice…comes with 5 different connectors, with a black carrying case.
Rebuilt - ZERO miles D16z6 transmission, no miles since rebuild
Auto meter Gauge Cluster Bezel
-Black, fits a 99-00 Honda civic…
Greddy Boost Gauge
-60MM (never hooked up)
Greddy EGT Gauge
-60MM comes with probe (never hooked up)
85% tread…
Greddy Boost Gauge
Greddy EGT Gauge
Originally posted by mitsurugi
How much are you looking to get for the flywheel? Does it fit a d16z6? Thanks
