Window and Window Regulator, Help
Window and Window Regulator, Help for 88 Legend
Hey I got into a wreck with my 88 Legend and I had to get my door replaced. Well I need to know how to put my window on cause I am completely clueless. I have the door panel off, I just need to know how to install the window and the regulator, this will help me out a lot. Thanks.
It helps to have a second person help hold the window glass while the other person bolts/unbolts it.
Once you have the regulator unbolted from the door and window, you have to get the regulator out of the inside of the door. It's a small hole, and requires some patience to get the regulator through.
The hardest part is getting the new regulator bolted inside the door. The motor is relatively heavy and located far away from the hole, so it's difficult to position is properly.
The online workshop is linked to on acura-legend.com.
