disconnecting antenna....
Old 09-25-2003 | 12:18 PM
TarHeeL-Si's Avatar
TarHeeL-Si
Default disconnecting antenna....
hey guys i searched but was unsuccessful. all i want to do is make the antenna stop going up and down...what is the easiest way to do this
thanks
kellen
Old 09-25-2003 | 03:08 PM
VPUPPY's Avatar
VPUPPY
do you have an aftermarket head unit? if so, on the harness off the radio you can cut the antenna remote wirethis wire is what makes the antenna go up. also, be careful not to confuse it with the remote wire, if you have external amps they will stop working. i would suggest you place a switch so you can put it up when you need it to.
Old 09-25-2003 | 03:56 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
go to the back of your trunk, open the rear plastic quarter panel on the left side, look for the power antenna motor, spot two wire plug, and disconnect. your radio reception is gonna suck ass after this... hope you got some good cd's/mp3's :goodjob:
Old 09-25-2003 | 04:33 PM
kfar09's Avatar
kfar09
thats what i did... sometimes i wish i could listen to the radio but they j/ outplay every song. the stock antenna looks like ass when its up. either go S2K antenna or disconnect the stock one. any aftermarket hu's come with a built in antenna?
Old 09-25-2003 | 04:42 PM
kfar09's Avatar
kfar09
j/w but do type r's have antennas? im drawing a blank
Old 09-26-2003 | 04:42 PM
XSrcing's Avatar
XSrcing
get an alpine headunit. it only raises the antenna when you are listening to the tuner.
Old 10-01-2003 | 08:08 AM
megateg5675's Avatar
megateg5675
i just bought an s2k antenna and it is freakin sweet....the reception isnt the best but it looks so much better and if you listen to cd's all the time then u dont got to worry about it
Old 10-01-2003 | 10:32 AM
LT's Avatar
LT
The deer had to die!
like i said in my other antenna post - just wire in a bypass switch. Switch it on, the antenna mast rises, when you want the radio. Switch it off, the antenna goes and stays down, when listening to a CD.
Old 10-01-2003 | 10:35 AM
dave0283's Avatar
dave0283
i agree. thats what i did to mine. its barely up because i always listen to CD's but when i need it i just flip the switch.
Old 10-01-2003 | 10:54 AM
JGordon's Avatar
JGordon
My antenna switch works great. Plus, it gives you that wonderful "Bling-Bling" of having custom installed switches in your interior.:thumbup:
