disconnecting antenna....
Originally posted by XSrcing
get an alpine headunit. it only raises the antenna when you are listening to the tuner.
Originally posted by LT6916
like i said in my other antenna post - just wire in a bypass switch. Switch it on, the antenna mast rises, when you want the radio. Switch it off, the antenna goes and stays down, when listening to a CD.
- what kinda wire did u get it?
- and the switch i bought is a lil small for the hole, is there something i can put behind the switch and cut a little hole in it to allow that wires to get thru that will stay on there? i dont know if i xplined myself
and if im correct the wire im looking for is a "YELLOW wire w/ a GREEN line"
i just used a regular 12v capacity wire. i cut out a rectangular hole into one of the blanks sitting in the center console (along the ebrake) and jammed the switch in there.
you're correct about the wire color.
this article is what i followed.
http://www.sandmracing.com/
Click on upgrades & mods then scroll down to electrical. You want the Antenna Switch on the right side.
