Difference between USDM ITR tranny and JDM ITR tranny?
Old 07-15-2002, 04:47 AM
xtrmcheeze
xtrmcheeze's Avatar
Default Difference between USDM ITR tranny and JDM ITR tranny?
I was wondering if there was any difference between the USDM ITR transmission and JDM ITR transmission? I bought mynew ITR tranny last week and installed it, and the guy I bought it from said that since its the JDM version, it comes with a different final drive gear, is this true? Im just wondering, plus I have never driven a type R before, so I wouldnt be able to tell any difference.... also, is there any special type of tranny fluid I should use since I now have LSD?
Old 07-15-2002, 05:54 AM
qtiger
qtiger's Avatar
JDM ITR transmissions have a MUCH higher final drive than USDM.
It does also have lower ratio 4th and 5th so that you aren't at 6K RPMs on the freeway.
Old 07-15-2002, 08:23 AM
xtrmcheeze
xtrmcheeze's Avatar
ok, that explains everything, thanks!
Old 07-15-2002, 10:25 AM
dom93hatch
more meat, more fire
dom93hatch's Avatar
Doesn't the JDM one have LSD?
Old 07-15-2002, 11:06 AM
xtrmcheeze
xtrmcheeze's Avatar
Im pretty sure they both have LSD, I know this JDM one does...
Old 07-15-2002, 11:36 AM
slickboy
ECHC junkee
slickboy's Avatar
they both do.
Old 07-15-2002, 11:50 AM
qtiger
qtiger's Avatar
LSD is AVAILABLE on the SiR-G, not standard.
Old 07-15-2002, 12:44 PM
98EX
Insane Wierdo
98EX's Avatar
Do you mean a shorter 4tha dn 5th cause the JDM are short than the USDM which means that on the freeway your RPM's are going to be higher than that of a USDM
JDM tranny................USDM tranny
S80............................Y21 Y80 S80 S4C
3.23............................3.23.............. ........1st
2.105..........................2.105.............. ......2nd
1.458..........................1.458.............. ......3rd
1.034..........................1.107.............. ......4th
0.787..........................0.848.............. ......5h
3.................................3............... ............Reverse
4.785..........................4.4................ ........Final
Old 07-15-2002, 12:52 PM
qtiger
qtiger's Avatar
Higher = shorter gears
Lower = taller gears
And, btw, that information is wrong, only the USDM S80 LSD (Type R trans) has those gear ratios. The Y80 and nonLSD S80 both have 4th and 5th ratios matching the JDM Spec R transmission.
Old 07-15-2002, 12:59 PM
98EX
Insane Wierdo
98EX's Avatar
Nope those numbers are right, I referenced them against a program I have that can calculte true speeds based on tire size, and gear ratios, and against http://www.bseries.net/html/specs/btrannyspecs.php
Also this site has the same gear ratios
http://www.allmotorhonda.com/techpag...anny_specs.htm
The ratios are the same as I posted up.
Quick Reply: Difference between USDM ITR tranny and JDM ITR tranny?
