hatch release prob.
Old 08-27-2003 | 12:48 PM
99GSRbeerman's Avatar
99GSRbeerman
There is a speed limit?
Default hatch release prob.
my switch gimik isnt workin on my teg!!!
when i press the lock or unlock button it makes noise like it usually did and when i use the switch i hear somthin move but the hatch dosnt pop!! i have to use the key to open it... whats wrong with it?
Old 08-27-2003 | 01:43 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The cable is probably slack, and therefore unable to release the cam & spring lock at the rear hatch. I'd grab a Haynes or Heims manual and check it out.
If the solenoid isn't actuating, you may have a continuity issue with your wiring. Check the ground wire first.
Old 08-27-2003 | 01:52 PM
Daniel's Avatar
Daniel
Did you perhaps wrap the metal hook with electrician's tape? Wrapping it too much lodges it into the release mechanism and it won't open.
Old 08-28-2003 | 05:18 AM
99GSRbeerman
i didnt wrap anything. it makes noise like it wants to do somthin...... but the funny thing is this morning it works???
