Rear speaker wire - which on is + and _
Old 08-31-2003 | 05:25 PM
Spec R's Avatar
Spec R
Originally posted by 3 plus 1
Speakers are running off an Alpine 9813 (60wx4). And thats real. I had to wire the damn thing direct to the battery (it'll run with the key out of the ignition too). Sounds pretty good. But kappas are known for shitty bass and for the time being I've got some badass mids and highs, but pretty much zero bass. Just have to put the sub in. And it looks totaly stock. You cant even tell I ever took the thing apart.
Whoa, if its direct to the battery like that, then there's some danger in the installation...
You at least want a fuse, remote power wire, and a decent ground, but if you're happy with your improper setup, its all good.
I say, to the very least, change that wiring setup when you get your sub and another amp.
DB Squad
Integra Forum Moderator
Old 08-31-2003 | 05:31 PM
Spec R's Avatar
Spec R
DB Squad
Old 09-01-2003 | 09:25 PM
Toyz51's Avatar
Toyz51
The high powered Alpines should be wired directly to the battery with at least a 12 ga. wire and should be grounded to the chassis. He did nothing wrong as long as the wire is fused at the battery and is run through the firewall with an insullated grommet.
Old 09-01-2003 | 09:33 PM
Spec R's Avatar
Spec R
If there's nothing wrong, how come he can turn it on without the Key in the ignition? I can be wrong, but i'm just confused.
DB Squad
Old 09-02-2003 | 10:22 AM
3 plus 1's Avatar
3 plus 1
Its dont perfect. I've done a million installs before. This was no different other than the power wire to the batt. The deck doesnt get power through the circuit board (powered by the ignition) but instead direct from the battery. Which means its still a perfect install, but its fully powered directly off the battery. There are no relays to interupt it. And I ran the power wire off the battery through the gromet (drilled a hole in it) and sealed it so no hot air can leak in. I need to get some pics taken. Its pretty well done. Sadly when I'm gonna have to go back in there again to install the amp. And when I do that I'm going to mount the gauges in a custom pod where the tray used to go. That'll be fun.
Old 09-03-2003 | 12:30 AM
Spec R's Avatar
Spec R
Makes sense. Where's this "circuit board" you speak of? I'm gonna keep my install the same, but i just wanna know out of curiosity.
DB Squad
Old 09-04-2003 | 11:29 AM
3 plus 1's Avatar
3 plus 1
Your stock radio runs through the fusebox before going to the batt. Mine has a direct wire to batt with fuse on it. So it is really in no way controled by the car. I wouldnt do it unless you get a deck that requires it. Mine is one of the very few that does. Pretty badass deck though. Sounds badass. Not cheap. h:
Old 09-04-2003 | 11:43 AM
pnthr30's Avatar
pnthr30
Default G3 Wiring
From Team-Integra.com
G3 Acura Integra
12V|White|+|Ignition Harness
Starter|Black/White|+|Ignition Harness
Ignition|Black/Yellow|+|Ignition Harness
Accessory|Yellow|+|Ignition Harness
Power-Lock|Black/White|-|Drivers Kick Panel *2
Power-Unlock|Black/Red|-|Drivers Kick Panel *2
Parking Lights|Red/Black|+|Green Plug Above Fuse Box *3
Headlights|Red/White(low)12awg|+|Steering Column
Door Trigger|Lt.Green/Red|-|Drivers Kick Panel *2 *4
Dome Supervision|Use Door Trigger
Trunk/Hatch Pin|Green|-| *6
Trunk/Hatch Release|Blue|-|At Switch *7
Tachometer|Blue|Distributor *1
Brake Wire|Green/White|+|Brake Switch
Horn Trigger|Grey or Blue/Green|-|Steering Column
Wipers|Blue & Blue/Yellow|-|Steering Column *5
LF Window Up-Dn|Red/Blue-Red/Yellow|A|In Drivers Door
RF Window Up-Dn|Blue/Green-Blue/Yellow|A|In Drivers Door or DKP
LR Window Up-Dn|Green-Green/Yellow|A|In Drivers Door or DKP
RR Window Up-Dn|Yellow/Green-Yellow|A|In Drivers Door or DKP
Sun Roof Open-Close|Green/Red-Green/Yellow|A|Sun Roof Switch
Radio 12V|White/Blue|+|Radio
Radio Ground|Black|-|Radio
Radio Switch|Yellow/Red|+|Radio
Radio Illuminate|Red/Black|+|Radio
Power Antenna|Yellow/Green|+|Radio
LF Speaker|Blue/Green-Grey/Black|Radio
RF Speaker|Red/Green-Brown/Black|Radio
LR Speaker|Blue/Yellow-Grey/White|Radio
RR Speaker|Red/Yellow-Brown/White|Radio
Old 12-02-2003 | 08:26 PM
rgbpmp's Avatar
rgbpmp
It should be installed kinda like an amp.
There is a power wire going to the battery. And a wire that goes to the ignition to switch on the radio. Like an amp, the remote wire gets a small signal from the radio to turn the amp on but it actually draws power direct from the battery.
If it was installed correctly, it should only be functional when the ignition is in the "on" position.
Old 12-02-2003 | 11:49 PM
Spec R's Avatar
Spec R
Wow, brought back from three months ago.
DB Squad
