springs
Old 07-09-2003 | 06:28 PM
b00gers's Avatar
b00gers
95teg: IMO, the shocks will last another 10k with those springs on. then you are going to have to get a new set. meaning more time spent wreching the car.
Old 07-09-2003 | 07:31 PM
Hondavirgin's Avatar
Hondavirgin
so its true that you match shocks to springs and not the other way round?
Old 07-13-2003 | 08:12 PM
95TEGGY's Avatar
95TEGGY
So after 10 k can i just put on some tokico shocks or will they not work on newspeed springs?. " BY the way i messed up, im gettin newspeed not eibach, i dont know if that makes any difference." Thanks
Old 07-14-2003 | 02:29 PM
b00gers's Avatar
b00gers
its neuspeed, btw.
yes you can do that. but do you really want to take apart your suspension again? and also taking the car to get another alignment>?
Old 07-14-2003 | 05:47 PM
95TEGGY's Avatar
95TEGGY
wait so when i change the springs, imma have to get it realigned?
Old 07-14-2003 | 06:07 PM
DB8's Avatar
DB8
Yes I think you'd have to get it realigned. It is probably best to change your shocks along with your stiffer springs. The stock shocks are not designed to handle the travel of the stiff springs, and your car will be really "jumpy." If you want to improve handling, you should upgrade the shocks as well.
Old 07-14-2003 | 06:52 PM
b00gers's Avatar
b00gers
YES! or else the tires will be gone. taking apart the cars suspension will mess the geometry up. the camber / caster / toe readings all will be thrown off.
if you have a wheel works, they do alignments for about $70, which includes a year warrenty. so within that year, you can take it back whenever. ive already had it done twice in the past couple months. and i plan to go back a couple more times. and once more right before the warrenty ends.
EXACTLY.
Old 07-14-2003 | 07:20 PM
95TEGGY's Avatar
95TEGGY
Thanks ill check it out
