my a/c isnt cold..how can i diagnose the problem?
Old 06-27-2003 | 09:14 PM
ambition's Avatar
ambition
StillDPG
Originally posted by LudeRage
:werd: contrary to popular belief, maryland is hotter than California. Fawk you humidity! :madfawk:
Arizona is hotter then mayland stop bitching :fawk:
Old 07-13-2003 | 08:24 AM
Jdogg96's Avatar
Jdogg96
I have also had the same issue along with gauges going off the chart, engine getting too hot and problems with not starting. For me it was the bottom grounding strap attached to the trany. The only grounding wire to the block aside from the one attached to the valve cover (and that path is issolated from the block by gaskets). My mechanic failed to tighten it, now that it is tight, my A/C is back and other related problems are gone.
Old 07-13-2003 | 04:44 PM
ADRteg's Avatar
ADRteg
the old system r12? is expensive as anything to change into the new one...my a/c is out too, but i'm only driving it for another month before college so i'm not gonna fix it, it was like 90 bucks for the shop to charge it (that's if there are no leaks)
Old 07-13-2003 | 09:46 PM
drdavidge's Avatar
drdavidge
well i got my freon professionally sucked out/recharged and it didnt help, expect the compressor dosent turn on and off going crazy anymore. what should i check next?
