Auto Teg 1/4 Mile Times
Old 07-02-2003 | 07:15 PM
Chrgsr96's Avatar
Chrgsr96
Whoops, I got them confused. What would cause my car to run lean?
Old 07-02-2003 | 07:25 PM
Kai's Avatar
Kai
Rotorphile.
Dirty injectors, clogged fuel filter, low fuel pressure, broken sensors, etc.
Usually the first two.
Old 07-02-2003 | 07:32 PM
Chrgsr96's Avatar
Chrgsr96
I'll run a bottle of fuel injector cleaner, and I have to change my fuel filter here soon. Hopefully that helps.
Old 07-02-2003 | 10:46 PM
pomansouth's Avatar
pomansouth
dont run lean too long cause you will detonate.
Old 07-03-2003 | 11:04 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Default Re: Auto Teg 1/4 Mile Times
Originally posted by acuraman69341
Anyways, My best time through the 1/4 is 20.xx @ 73mph
:lmao:
Snoopy, i think you found some competition with your "ride"
Old 07-03-2003 | 11:05 AM
teg_fan's Avatar
teg_fan
I like integra's
Now damn, I'm no shingo or fat booty, but that sounds damn slow to me, no offense acuraman. Either your not pushing you car too hard, or its not running right. <-- or I just didn't know that there was that much of a difference between manual's and autos.
Old 07-03-2003 | 11:51 AM
Chrgsr96's Avatar
Chrgsr96
Would that be when I am taking it up in the high rpms, and I hear like a loud, not too loud, but decently loud noise? Like detonation. Yea I think I've detonated a couple of times already. But its been real sparingly. Like a few months ago, and then maybe like once a month ago. Not like a whole lot. Is it causing harm?
I just recently installed an Adjustable Fuel Pressure regulator, and I'm running it at a higher psi because of my new cams, so it can't be running lean cause of psi. Plus I've not heard it in a long time, not once since hte new FPR. So I don't know. Maybe I fixed it.
Old 07-03-2003 | 12:36 PM
Kai's Avatar
Kai
Rotorphile.
Originally posted by Chrgsr96
Is it causing harm?
Yes, it will destroy your engine.
Do you have a fuel pressure gauge? Without one of those you have no idea what the real fuel pressure is.
Old 07-03-2003 | 01:54 PM
Chrgsr96's Avatar
Chrgsr96
Yes I have a FPG. I bought the guage and FPR when I got the cams and cam gears just recently. I bumped the fuel flow up 4psi, like skunk2 recommended with their stage 1 cams. But I'm going to get my car dyno tuned here with in the next couple of weeks anyways. So shouldn't they fix this problem anyways?
Old 07-03-2003 | 07:24 PM
Kai's Avatar
Kai
Rotorphile.
But I'm going to get my car dyno tuned here (...) shouldn't they fix this problem anyways?
Only if you have an air-fuel controler, programmable ECU, or something similar. A fuel pressure regulator is not a very exact tuning tool, as is changes the air/fuel along the full rev band with only one adjustment. If the lean condition is due to a mechanical problem with your car, having someone try to tune it out is not the way to go.
How many miles does your car have on the clock? Have the injectors ever been cleaned and balanced? Fuel injector cleaner is more of a preventative maintinace item, it will not clean and balance old and dirty injectors. I did hear of a trick that involves using four bottles at once... but I would advise against it.
