JDM TypeR Transaxle conversion
Hello all knowing ones. I have a tech question for you. I recently aquired a JDM Type R transaxle. My daughter and I have a pretty serious LS project car going. I was just thinking....(problem for sure)....are the LS axle stubs the same size as the Type R? I know the outers are bigger and also of course 5 lug but I need to know if the LS stubs will fit the Type R LSD. Obviously I can throw the caliper on the axles myself but you folks I'm sure know the answer much quicker.
Thanks for your time!
i have a set of jdm 5 lug conversion myself.. the ponly problem is that i dont have the axles.. and i know that i have to use the 36mm set.. .but i heard that it could be possible to use the cr-v axle!! just curious to see if any out there knows thanx,... geovannie_017@hotmail.com
