Koni Coilovers... what else?
Hey,
First off.. I have the chance to buy a set of Koni Coilovers for 600 bucks from a guy I know in town... they are used... whaddaya guys think? I'm also thinkin of buyin some Brembo rotors, should I go cross drilled, slotted, 'plain'. The final question (I'm sorry, but you guys know what you're doin, and I have to ask somebody).. what else should I change once I'm down there? The GSR I just bought has 140,000 miles, and it's driven in New England. Thanks again everybody .. we're gonna make this car FAST!!!!
I thought Koni only made shock absorbers
Maybe you're getting coilovers matched with Koni shocks. A popular combo would be Koni Yellows/Ground Controls.
As for the Brembos, I suggest going with Brembo blanks. No real reason to go for cross-drilled and/or slotted because you would actually lose contact area between the pad and the rotor. Blanks would be fine unless you're going to make the car a track slut.
Koni does make coilovers, but how they perform I don't know.
If you want to stop fast, you want to change to better calipers, and get bigger rotors: more surface area on the rotors being squeezed by stronger calipers. You'll probably need bigger rims too to accomodate the bigger brakes.
