AEM V2 Intake
Old 06-10-2003 | 06:45 AM
ur31337's Avatar
ur31337
Colby
Originally posted by ambition
if you have to swap out motor mounts 4 a freakin exuast thats is really ghey! most of you have intake tubes already if you are going to spend 200 bucks to gain an extra 2 h.p. your really stupid... an intake is only going to do sooo much. what about a bored t.b. or skunk2 manifold or somthing else to help your engine breath....
i got an rs akimoto and it more then does the job with my k&n air filter
Well, sounds like you won't be buying it.
:cry:
Old 06-22-2003 | 07:00 AM
azmi222's Avatar
azmi222
Default V2 Intake
I put one on my 00 GS-R about three weeks ago and I think that it has made a big difference. The biggest increase is in the higher RPM range between VTEC engagement and Redline. With the stock air box the car seemed choked off at high RPM's. I changed from stock so the difference was dramatic, my friend has an 01 GS-R and he had an AEM CAI before he also says that he can feel a difference.:thumbup:
Old 06-24-2003 | 10:49 AM
vaDave's Avatar
vaDave
ain't nothin' like the butt dyno :driving:
Old 06-24-2003 | 10:56 AM
azmi222's Avatar
azmi222
It is not just a heat shield either. Inside of the large pipe there is a pipe that is the diameter of the throttle body and AEM says that by adjusting the length of this "pipe within the pipe" they can effect where the performance increases are within the RPM band. If it were a heat shield the internal pipe would run down to the filter.:naughty:
Old 06-24-2003 | 11:26 AM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
i jsut bought be a regular AEM CAI.. ahh well who cares.. its like 100 bucks difference =T.. only a few HP difference.. In the long run... it wont affect much
