engine rebuilding tips
JDM rox ur world
My teg's got a leaky head gasket so i'll have to replace it sometime. But when i do that, while they're in there, anything else I should replace that might be worn out and not as smooth anymore? ie pistons, rods, other seals, etc... thanks for reading, or maybe some suggestion on better parts? its a 94 LS
Also check out the Hayes Manual or some other since typically during a particular repair section, they list items that should be done at the same time or problem areas to inspect.
replacing the headgasket... u can get cams, camgears, port the head, valves, val springs, val seals, port intake mani, if your going to take off the timing belt u might want to replace the waterpump.
