my gsr redline at 7500!
Old 06-28-2002 | 09:00 PM
swtchink13oi4u's Avatar
swtchink13oi4u
Default my gsr redline at 7500!
something is wrong with my gsr guyyy!! it redline at 7500 instead of 8200 wut the hell...anyone knows what wrong?
Old 06-29-2002 | 05:18 AM
newgsrdriver's Avatar
newgsrdriver
Check the oil level?
Old 06-29-2002 | 07:11 AM
UVAzN's Avatar
UVAzN
From: Charlottesville, VA (school)/McLean, VA (home)
thats too bad.
Old 06-29-2002 | 07:13 AM
tommyboy's Avatar
tommyboy
ImportXpression OG
Originally posted by UVAzN
thats too bad.
hahahhaa, your sensor is mess up..
Old 06-29-2002 | 07:32 AM
swtchink13oi4u
Default huh
i just change the oil so it should be fine..and the sensor?? what?
Old 06-29-2002 | 07:43 AM
newgsrdriver
How much did you put in, and how long ago? If you're low on oil, you will cut off early.
Have you tried resetting your ECU? (Pull the neg terminal off the battery for 10min, just make sure you have your radio code)
Old 06-29-2002 | 07:47 AM
swtchink13oi4u
Default heh
I know for sure it not the oil...haha trust me guy...hmm ecu reset i'm gonna try that and see what happen...and if it not that then dyam i dont know wut else to do....
Old 06-29-2002 | 10:49 AM
airon's Avatar
airon
AARONNOJIMA.COM
redline on a gsr is 8000
anyways are you saying fuel cut-off is at 7500 or redline? cuz if fuel cutoff is at 7500 then your probably running in safe mode for some reason. are you throwing any check engine light codes?!?!
Old 07-01-2002 | 12:38 PM
riceking3's Avatar
riceking3
its p28 ecu cause i have one in my gsr check ecu !!!!!
Old 07-01-2002 | 02:24 PM
red GS-R's Avatar
red GS-R
shhhh...just be quiet.
To reset the ECU properly, open the fuse box in the engine bay, pull out the fuse labeled '7.5' for 10 seconds, then put it back in. Start your engine and let it run with no accessories on for about 5 minutes until it warms up.
My GS-R did the same thing and now the check engine light is on, my car dies when I put the clutch in after driving, and it idles REALLY low. It also redlines at 3500 RPMs. Yes, 3500.
Also, put on your lap belt, I think that might have something to do with the fuel cutoff.
Quick Reply: my gsr redline at 7500!
