missed 4th gear
Old 06-28-2002 | 07:53 AM
riceking3's Avatar
riceking3
Default missed 4th gear
i misshifted to 2 last night on the freeway and it hit 9000 rpms could anyone tells me what can be the problem..i hear a slight ticking when the car is idle and when i pop the hood
Old 06-28-2002 | 08:17 AM
slickboy's Avatar
slickboy
ECHC junkee
What model integra do you have? The GS-R(b18c1) and Type R(b18c5) can rev a lot higher than the RS\LS\GS(b18b) can. I mis-shifted one time just as you did. Hit about 8,000 in 2nd gear in my old 91 LS teg, which redlines at like 6300 I believe, it turned out to be fine. If it cranks up okay, you should be alright. If you start hearing knocking soon...umm..it's not ok.
Old 06-28-2002 | 08:20 AM
riceking3's Avatar
riceking3
a b18c1 but i have a p28 ecu so i have to shift at 7 or so and when i missed shift i took my foot of the gas pedal quickly and saw the rpms where at 9
Old 06-28-2002 | 09:12 AM
LT's Avatar
LT
The deer had to die!
REPOST! but that ticking could be just you now noticing how loud the injectors are.
Old 06-28-2002 | 09:20 AM
maxrpm's Avatar
maxrpm
can also be your valves or it can be that you might have bent some valves. It probably not that bent but enough to be noticed. My integra had bent valves on number 3 piston when i took my head off. i did the same thing as you did.
Old 06-28-2002 | 09:33 AM
1funride's Avatar
1funride
99 Integra LS
Default Re: missed 4th gear
9k in 2nd!
imo, i would have it checked out..
Old 06-28-2002 | 10:01 AM
Excelesor's Avatar
Excelesor
Platinum Member
that clicking noise is more than likely your valves. You may wanna get a compression test, that'll tell you whats wrong. You may only need to get your valves realigned. what are your rpms at idle??
Old 06-28-2002 | 12:49 PM
riceking3's Avatar
riceking3
rpm idle at 800and below but its around 700 or 800....
Old 06-28-2002 | 03:48 PM
Weston's Avatar
Weston
I don't think 9k is so bad for a GS-R engine. I accidentally hit 8k in my LS once and everything was fine. The ticking you hear could be your fuel injectors and/or valves. Mine got a lot quieter after a valve adjustment, but there's still a lot of ticking from the injectors. In fact, the injectors are so loud that my friend thought my engine was all messed up when I had it idling with the hood open once.
Old 06-28-2002 | 09:03 PM
SpeedDemonX's Avatar
SpeedDemonX
If your block wasn't cracked from the incident ( which i doubt ), then the tapping noises are coming from your valves. Just goto a shop and get them re-aligned, and the noise will go away.
Quick Reply: missed 4th gear
