Gsr rear brake problems.
i got an 99 integra gsr and i changed my rear brake pads like a year ago, but the driver side rear works and the passenger rear doesn't work when i pull the e-brake . when i pull the e-brake it goes all the way up and only the driver side rear brake works. When i brake all four of them work but the passenger side is a little slow.
oh i tried that already.
didn't work. the driver side cable is more tense than the passenger side one.
the passenger side cable pulls all the way up making the bracket look like this "/". if you get the picture.
u cant use a c-clamp on the rear, its the turning kind with the X.
maybe you didnt get the brake pad nimple in the groove of the "X"?
DB Squad
Integra Forum Moderator
DB Squad
yes you can use a c clamp in this kind of situation. i forgot you need an ajjustable plier to turn the piston while pressing with the c clamp... works coz inve done it a couple of times at the shop. new trick eyy
